Author Topic: Radeon 4890 calamity driver  (Read 8026 times)
iori01
  • Last login:May 18, 2024, 05:41:12 pm
« on: September 15, 2011, 11:41:05 am »
Hi gents,
thanks to the modification calamity performed, I'm now able to use my 4890 with calamity driver 9.3
I performed some quick test with calamity 9.3 and catalyst 11.x + soft15khz
Playing with SSVIAE 480i on my New astro city and the result is far better with Catalyst 11.x + soft15khz as I can use AA filter that no working with Calamity 9.3
But I would like also use groovymame so I have an issue.
Is it possible to tweak a newer catalyst with all those modelines ?
Or at least provide the full list of modelines used in calamity driver to inject with Soft 15 Khz on a catalyst 11.x ?
Many thanks in advance for your help.
Calamity
  • Moderator
  • Last login:Today at 01:48:37 pm
  • Quote me with care
Re: Radeon 4890 calamity driver
« Reply #1 on: September 15, 2011, 03:44:02 pm »
If you run VMMaker with the right options, it will output a file named Modeline.txt, open that and copy those modelines into Soft15khz's custom list. However, you'll be limited to the maximum number of modes supported by non-hacked Catalyst drivers (60).
You can also use VMMaker to "inject" those modelines for you, just make sure to enable the option "AnyCatalyst" in vmmaker.ini.
If you're going to go through that please do a favour to me. Go to this post and grab the groovymame/vmmaker versions attached:
http://forum.arcadecontrols.com/index.php?topic=110905.msg1209299#msg1209299
... I'm interested to see if the "magic" resolutions thing works for some other Catalyst version. It would be great as it would make the 60 modes limitation irrelevant. Make sure to run groovymame with -video d3d.
Steps to create a log:
thefooz
  • Last login:January 19, 2012, 08:10:33 pm
« Reply #2 on: September 16, 2011, 03:49:32 pm »
Calamity,
This would still only work in XP though, right? I think recall you saying something about Windows 7 having issues with refresh rates.
Calamity
  • Moderator
« Reply #3 on: September 16, 2011, 03:57:36 pm »
Calamity,
Yeah everyone intending to do some serious use of CRTs should stick with XP, until the Win7 thing is fully figured out (might not happen). On the other hand LCD support is already functional in Win7 via PowerStrip (if your LCD monitor can deal with variable refresh rates).
iori01
« Reply #4 on: September 22, 2011, 11:51:04 am »
thanks a lot for this Calamity,
Will try to perform some test and let you know asap.
Not now as out for vacation  ;D
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #5 on: December 28, 2011, 08:50:29 pm »
what happened?
