Author Topic: Help using Mala with IPac and X-Arcade  (Read 2329 times)
sandman235
  • Last login:November 17, 2011, 01:13:09 pm
« on: September 14, 2011, 02:35:21 pm »
So I am running Mala with X-arcade as my controls but I want to also run I-Pac because I have my coin door set up on it. How would I go about running both of them? Like I said all the I-Pac is doing is telling it a coin has been put in the coin door and X-Arcade is doing everything else.
MiahXGaming
  • Last login:May 26, 2016, 02:42:21 pm
  • Legend
    • X-Arcade
Re: Help using Mala with IPac and X-Arcade
« Reply #1 on: September 15, 2011, 09:20:19 am »
Perhaps you can connect the coin door to the X-Arcade instead, see our coin door manual here:
http://www.xgaming.com/support/questions/115/
Otherwise the iPac would act as it's own input, so it shouldn't affect what the X-Arcade does.
