Author Topic: Another Knievel Inspired Cab - FINISHED  (Read 14103 times)
lilrascal
  • Last login:April 09, 2016, 05:26:38 pm
« on: September 09, 2011, 05:22:45 pm »
Well I promised to post a build thread.  I am very early in my project, and hope to journal my progress as I move along.  As many others, I was inspired by Knievel's work.  I liked the woody, but more the curved lines of the evo.  I am going to use the Hanns G 27" LCD that is 16:10.  Because of the increased width of the cab (around 26"), I wanted to increase the depth slightly to make it more proportional.   Thanks to TopJimmyCooks was nice enough to help by modifying the original sketchup work that EvilNuff had done.
I am planning on making it out of maple ply, and staining it a dark color.  I wanted to make a template that I could use, to route the more expensive maple ply.  I couldn't find any 4x8 sheets of 1/4" mdf, so went with 1/4" luan ply.  I am sure I will be asking for input and advice along the way.  Here is a picture of the template all cut out:
« Last Edit: November 04, 2011, 03:32:09 pm by lilrascal »
Donkbaca
    • Slim built MAME/Xbox cab
Re: Another Knievel Inspired Cab
« Reply #1 on: September 09, 2011, 06:19:23 pm »
Good luck!  And take your time!  I built a woody-ish cab.  (check out my sig)  and if you are new to wood working, make sure you take your time, keep things clean, and enjoy it!
TopJimmyCooks
« Reply #2 on: September 09, 2011, 09:20:36 pm »
Looking forward to the build and that big LCD.  Are you going to bezel it down to 4x5 or use the full aspect?
lilrascal
« Reply #3 on: September 10, 2011, 08:57:02 am »
Right now I am planning on leaving the full aspect for hyperspin, and having the mame games run in their original aspect. I am planning on having tinted plexiglas over the monitor. Hopefully that will work. Not really original arcade, but that went out the window with a woody cab I guess.
Donkbaca
« Reply #4 on: September 10, 2011, 12:18:16 pm »
If the inside of the cab is sealed pretty well and if the glass is right up against the monitor it will look good
lilrascal
« Reply #5 on: September 11, 2011, 10:51:46 am »
Well I finished getting the sides made this morning.  I used a router and pattern cutting bit to cut the two pieces of maple ply.
lilrascal
« Reply #6 on: September 29, 2011, 11:32:14 am »
Got some more work done this week.  Got the shell all made.  Just need to finish up some small things including the keyboard drawer.  I decided to not have the front open up.  Instead I made the back removable using some threaded inserts.  I am happy so far with how it is turning out. Sorry for the crappy pics, shop is a mess, and it is hard to get decent shots.
Donkbaca
« Reply #7 on: September 29, 2011, 11:40:46 am »
I would ditch the keyboard drawer if its not too late.  It adds complexity, gives another gateway into your cab for nosy folks, and isn't all that useful.  The best way to set up a cab is to get the software stuff all set up and then migrate the computer in.  If you aren't opening the front, I would suggest putting in a coin door to give you access.  If you ever need to do maintenance, you could just open the door.  It doesn't make sense to build a feature into your cab (keyboard drawer) that isn't useful, and that you will only need during the setup of the cab.
lilrascal
« Reply #8 on: September 29, 2011, 02:01:13 pm »
Thanks for the feedback.  I am planning on sticking with the keyboard drawer though.  I don't find it overly complex.  And the way it is on Knievel's is pretty discreet.  Planning on skipping the coin door for now, as they are pretty pricey.
TopJimmyCooks
« Reply #9 on: September 29, 2011, 04:38:13 pm »
For an all purpose, all emulator mame rig, a discreet keyboard drawer is a very nice and easy to implement luxury.  I agree i would bag it for a vert classic 60 in 1, multi-williams, or single game type cab.  On the knievel cabs its so far back under the cp that nobody's looking for it unless you know it's there.
Psykoholic
  • Last login:November 30, 2011, 10:38:13 pm
« Reply #10 on: October 07, 2011, 11:28:44 am »
This looks great so far!
lilrascal
« Reply #11 on: October 13, 2011, 12:13:27 pm »
Staining is coming along, but staining maple SUCKS!! :angry:  I used a pre-stain conditioner, then a gel stain by general finishes.  This is the 3rd coat.  The plywood parts don't look too bad, though the parts that are solid maple not so much.
lilrascal
« Reply #12 on: October 13, 2011, 08:33:00 pm »
Starting to think about a marquess.  Want something in a blue color scheme, fairly simple.  Don't want to use the word "MAME", as most people I know don't know what that means.  Not being real artistic, or good with editing software, I searched the arcade art library.  I was thinking of going with this arcade classics one.  Any thoughts or inputs??
lilrascal
Re: Another Knievel Inspired Cab - Stained - marquee advice
« Reply #13 on: October 14, 2011, 11:39:32 am »
Ugg.  Went to drill holes for my admin panel and mistakenly grabbed the 1-1/4 forstner bit instead of the the 1-1/8.    :banghead:
Now got to mill up a new piece of lumber and start over on it.
lilrascal
« Reply #14 on: October 19, 2011, 03:16:30 pm »
Well milled up some more lumber, and started on the box for the control panel.  Here it is dry fitted together.
TopJimmyCooks
« Reply #15 on: October 19, 2011, 04:58:49 pm »
Nice job mitering -looks good.
portugese pirate
  • Last login:March 06, 2025, 06:07:58 pm
« Reply #16 on: October 19, 2011, 05:44:36 pm »
+1 on the keyboard drawer.......I use mine all the time as the cabinet is online and makes it easy to add games to all emulators
lilrascal
« Reply #17 on: October 20, 2011, 03:42:52 pm »
Today I got the CP top cut out.  It is 1/2" mdf.  Over that will go a piece of 3/16" maple ply, and 1/16" lexan. This will give me a total of 3/4".  I will use this mdf as a template for routing the lexan, and plywood.
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
« Reply #18 on: October 28, 2011, 02:11:05 pm »
I like the overarm dust collection on the tablesaw.  What is that?
  • Last login:Today at 08:37:44 pm
« Reply #19 on: October 28, 2011, 03:22:42 pm »
Couldn't agree more. I don't need a keyboard on any of my cabs. Once it's setup, I leave it alone. Been running fine for years.
lilrascal
« Reply #20 on: October 30, 2011, 11:54:27 am »
It is a SawStop table saw.  It is there overarm dust collection arm, that is optional.  I love my SawStop, and the piece of mind it brings!!
Finishing some coats of poly this week, and then things should start to come together.  Got my marquee from Game on Grafix this weekend, happy with quality and speed of service.  Will try to update on the progress as things come together.
TopJimmyCooks
« Reply #21 on: October 30, 2011, 07:13:56 pm »
the sawstop is a great thing to have.  the safety feature is great and it's a quality tool to start with.  do you keep a spare brake cartridge in the event that you set it off over a weekend?  I guess I would.  Cab looks excellent.
GregD
    • Arcade Nebula
« Reply #22 on: October 30, 2011, 07:57:20 pm »
Haven't heard about the sawstops in awhile.  I remember the promotional videos with them running hotdogs through the blade.  Did they evr make a contractor saw?
EvilNuff
« Reply #23 on: October 30, 2011, 08:20:24 pm »
Yes but its $1.7k :)
lilrascal
« Reply #24 on: October 31, 2011, 12:42:56 am »
I just have the standard and the dado cartridge. I never was to worried about having a spare  I figure if I set it off, I would probably be scared enough that I would give it a day or two rest anyway!!!   :o
They do build a top quality product though. And their customer support is awesome.
TopJimmyCooks
« Reply #25 on: October 31, 2011, 02:33:21 pm »
. . . I figure if I set it off, I would probably be scared enough that I would give it a day or two rest anyway!!!   :o
That makes sense.  Be careful out there.  I really appreciate those things when working on my 60's era 8" TS with no guard, splitter or DC.
SammyWI
« Reply #26 on: October 31, 2011, 07:59:07 pm »
I think I'd spend a day or two cleaning out my pants.   :P
Nice looking cab so far.  Should turn out nice.
lilrascal
« Reply #27 on: November 01, 2011, 12:03:54 pm »
Control Panel top put together.  Now I have to just wire it up.  Kinda crappy pic, but here it is:
« Reply #28 on: November 01, 2011, 12:06:29 pm »
Very nice! :applaud:
GregD
    • Arcade Nebula
« Reply #29 on: November 01, 2011, 02:22:56 pm »
CP looks great.  It looks exactly like the Woody CP.  What did you use to make the ovals around the buttons?  Vinyl?
lilrascal
« Reply #30 on: November 01, 2011, 07:09:48 pm »
Used a couple black vinyl sheets at the Michael's craft store.  I believe Knievel used Happ vinyl, but this was easier than ordering that, although this does not have any texture like the Happ vinyl.  I got through about half the wiring today.  Will work on it some more tomorrow.
lilrascal
« Reply #31 on: November 02, 2011, 03:38:34 pm »
NovaMatrix Linx LED marquee lights installed.
lilrascal
« Reply #32 on: November 02, 2011, 06:11:50 pm »
Control panel box and admin panel installed.
lilrascal
« Reply #33 on: November 02, 2011, 09:09:00 pm »
Added the mount for monitor, and hung monitor to test fit.
lilrascal
« Reply #34 on: November 03, 2011, 10:20:15 pm »
Control panel all wired up.
lilrascal
« Reply #35 on: November 04, 2011, 03:31:42 pm »
All finished.  Am really happy with how it turned out.  To be honest the pictures do not do it justice.  Thanks to all those who provided input.
Re: Another Knievel Inspired Cab - FINISHED
« Reply #36 on: November 04, 2011, 03:36:06 pm »
You're missing a coin door.
But seriously, very nice job. You got it done pretty quick too! :cheers:
lilrascal
« Reply #37 on: November 04, 2011, 03:49:32 pm »
After I finished, I actually thought that it needed a coin door too.  Didn't really want too spend money on one, when I wouldn't be using it.  Maybe I will add one later.
« Reply #38 on: November 04, 2011, 04:34:49 pm »
Very nice!  That finish is awesome.
It might be my eyes playing tricks but yours looks a little thicker than Knievel's.  I like it.
lilrascal
« Reply #39 on: November 04, 2011, 04:43:27 pm »
Yes, I made it wider to accommodate a 27.5" LCD.  I made it a little deeper to compensate for the width.
