Author Topic: Retrieve game name list? (programming Q)  (Read 2016 times)
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
« on: September 09, 2003, 10:17:52 pm »
Hopefully someone can answer this for me:
1. How do I retrieve the MAME game list from VB? I've tried ShellExecute, Shell, and other various functions, but nothing works. The arguments I send are "-listfull >c:\filename.txt", but it won't save. I've also tried without the c:\, but it WILL NOT SAVE!
2. How do I get the names of NES games? Header?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Retrieve game name list? (programming Q)
« Reply #1 on: September 10, 2003, 12:16:50 am »
shell should work.  However you won't know when the execution is done.  Look on deja.com for ShellAndWait.  It VB code that uses windows api to execute and wait for finish of execution.
BTW, it's easier to parse -listxml since you can use Microsoft XML 4.0 DOM docs in VB.
« Last Edit: September 10, 2003, 12:18:22 am by SirPoonga »
DinoRoger
  • Last login:October 24, 2005, 02:00:37 am
  • Hey, can I borrow a quarter?
« Reply #2 on: September 10, 2003, 12:38:20 am »
Here is the Shell Wait code I use in most of my apps (VB6):
Private Declare Function OpenProcess Lib "Kernel32" (ByVal dwDesiredAccess As Long, ByVal bInheritHandle As Long, ByVal dwProcessId As Long) As Long
Private Declare Function GetExitCodeProcess Lib "Kernel32" (ByVal hProcess As Long, lpExitCode As Long) As Long
Private Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long)
Const STILL_ACTIVE = &H103
Const PROCESS_QUERY_INFORMATION = &H400
Sub Shell32Bit(ByVal JobToDo As String)
  On Error Resume Next
  Dim hProcess As Long
  Dim RetVal As Long
  hProcess = OpenProcess(PROCESS_QUERY_INFORMATION, False, Shell(JobToDo, 3))
    Do
      GetExitCodeProcess hProcess, RetVal
      DoEvents: Sleep 100
    Loop While RetVal = STILL_ACTIVE
End Sub
Example Use = Shell32Bit ("C:\MAME -fulllist > C:\ROMDUMP.txt")
« Last Edit: September 10, 2003, 12:51:59 pm by DinoRoger »
SirPoonga
  • Puck'em Up
« Reply #3 on: September 10, 2003, 03:42:53 am »
Don't you need to include some api calls there?
DinoRoger
« Reply #4 on: September 10, 2003, 12:50:19 pm »
Sorry forgot that. Modified my post with all code this time.
« Last Edit: September 10, 2003, 12:50:49 pm by DinoRoger »
EndTwist
  • Arg.
« Reply #5 on: September 10, 2003, 03:32:08 pm »
It still doesn't seem to work (I'm testing it on MAME 0.73)
Here is what I'm using:
Private Sub Form_Click()
Call Shell32Bit("C:\MAME\MAME -listfull > C:\ROMDUMP.txt")
End Sub
It shows the DOS window, but it wont save?! If I do it from the command prompt, it works, but otherwise--no?   ???
« Reply #6 on: September 10, 2003, 03:46:56 pm »
End Sub
Try this:
Call Shell32Bit("CMD.EXE /c C:\MAME\MAME -listfull > C:\ROMDUMP.txt")
(replace cmd.exe with command.com for Win98)
EndTwist
  • Arg.
« Reply #7 on: September 10, 2003, 03:50:51 pm »
[dramatic music]ba-ba-ba-baaaaa!
And that was the catch...It works!
Thanks everyone!  :D
