Author Topic: Best joystick for Defender/Stargate?  (Read 9350 times)
CIA_Guy
  • Last login:January 01, 2025, 10:33:10 pm
  • You mean there are games other than Defender?
« on: September 09, 2003, 08:34:00 pm »
I'm building a dedicated Defender/Stargate arcade machine.  Which joystick has the feel of the original?  The J-Stik has the ball top, but I'd sacrifice that for the feel (pressure and throw) of the original controls.
OSCAR
    • Oscar Controls
Re:Best joystick for Defender/Stargate?
« Reply #1 on: September 09, 2003, 09:00:56 pm »
This one is a bit more expensive than the Happ/Ultimarc sticks at $49, but Arcadeshop sells a reproduction Williams 2-way for Defender/Stargate/Joust.
http://www.arcadeshop.com/parts.htm#Joysticks
Apollo
    • Eight Bells
« Reply #2 on: September 09, 2003, 10:10:59 pm »
You usually need the original ( or reproduction ) to get the reverse button the right distance from the stick. If you use a different stick converted to 2 way then the reverse button has to be too far away from the stick ( doesn't feel right ).
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #3 on: September 09, 2003, 10:18:25 pm »
I had made a control panel using a Happs 2 way.  It was awful.  I ended up getting
a real Defender joystick on eBay for not too much money.  It's great, here's a pic:
http://users.adelphia.net/~bsturk/mame/pics/defender_cfg.jpg
Personally, I wouldn't go any other way.  I have lots of other types of joysticks
(gyruss, nintendo, wico leafs) and nothing feels as sloppy as that defender joystick.   :)
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Apollo
    • Eight Bells
« Reply #4 on: September 09, 2003, 11:06:29 pm »
That's beautiful, I'm inspired. My next project was going to be a 19" vertical but  I think I'll make 2 19" cabs at the same time, 1 vertical, 1 horizontal then I can play Defender, cool.
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #5 on: September 10, 2003, 11:08:30 pm »
I used the original layout using a repro 2-way -- can't beat it (I have swappable panels).
One thing I forgot about defender -- THE GAME IS HARD!!!
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #6 on: September 11, 2003, 06:28:53 am »
This game is hard and I think I'll never be any good at it, but I remember as a kid watching people who were champs at this game and I can't think of anything as exciting as watching one of these Defender Gods going for it! ;D
Apollo
    • Eight Bells
« Reply #7 on: September 11, 2003, 04:11:15 pm »
There are a few tricks you need to know to play it well, I think KLOV has some answers.
Grasshopper
« Reply #8 on: September 11, 2003, 04:28:14 pm »
Defender joysticks aren't actually supposed to be sloppy. It's just that most of the ones you come across are very worn. Hardly surprising as most defender machines are over 20 years old. I bought a couple of genuine (as far as I know) defender joysticks from an ebay seller a couple of months ago($5 each!). They are fairly stiff and have a short throw.
The problem with the design is that the joysticks use metal strips instead of conventional springs to generate resistance to movement. I'm guessing that the strips get bent over time causing the sloppy feel.
If you want a modern alternative then I'd suggest buying a 2/4/8 way switchable Seimitsu.
CIA_Guy
« Reply #9 on: September 12, 2003, 09:12:17 pm »
Maybe someone with access to a Defender console can measure how high the stick is (top of CP to top of ball) and the total throw length?   (Even approximate numbers would help.)
Thanks.
