Author Topic: J-Stik JLW TM 8 hollow shaft  (Read 1589 times)
cammada
  • Last login:August 01, 2020, 10:59:21 pm
« on: August 17, 2011, 07:04:10 pm »
After looking at Epyx's arcade cabinet and found the link to http://www.thludwig.de/arcade/led_sticks.html for the glowing joystick. In the Luigi's website has a link for Sanwa JLW TM 8 hollow shaft but in the arcadeshop.de doesn't show the product as the product was not found (http://www.arcadeshop.de/Joysticks-JLW-TM-8-Sanwa_723.html. Are they still selling the hollow shaft or should I go somewhere else?
Also do I have to buy seperate LED for hollowshaft?
should I order by email to led-sticks@thludwig.de or order through ArcadeShop.de?
Sorry as I am just a bit confused with the process but a help will be much appreciated.
Franco B
Re: J-Stik JLW TM 8 hollow shaft
« Reply #1 on: August 18, 2011, 02:34:07 am »
If luigi can't hook you up I still have a fair few JLW ones left over from when I was making them. I should have most colour LEDs too if you need one wiring up.
:oj
  • Last login:October 06, 2014, 04:56:47 am
  • Jim Knopf
    • Arcadeshop.de
« Reply #2 on: August 21, 2011, 10:39:34 am »
Sorry commada, it's out of stock for a long time. Because the JLW-TM-8 is discontinued since 2009, I don't intend to restock any parts of it. But I can really recommend to buy from Franco B  :cheers:
Arcadeshop.de - home of E-Limitator & Dual Strike
