Author Topic: Thoughts on LCD monitor for smallish arcade cab?  (Read 2664 times)
  • Last login:Today at 02:13:29 pm
« on: August 16, 2011, 12:29:00 pm »
Would something like this work OK?
Screen: 8 Inch TFT-LCD TV Monitor
Receive Frequency: VHF-1:49.75-160.25MHz, VHF-3:168.25-464.25MHz,UHF-1:471.25-863.25MHz
TV System: PAL(D/K, B/G, H, I, M, N), SECAM, PAL-M, PAL-N, NTSC
Audio Output: 150 mW(Max)
Back Light:    High-Brightness LED
Connection Terminal: TV Signal, Headphone, External Power, VGA Interface
Power Supply: DC 12V 2.66A
Power Consumption: <=12W
Max Resolution (pixels): 640 x 480@75Hz
Pixei Pitch: 0.297 x 0.297
View Angle:   160 Degree
Contrast Ratio: 400:1
Brightness: 400
Screen Ratio: 4:3
Color : Black
BobA
  • What Me Worry?
Re: Thoughts on LCD monitor for smallish arcade cab?
« Reply #1 on: August 16, 2011, 09:59:31 pm »
Looks like it would make a nice small monitor for a mini cab.
« Reply #2 on: August 17, 2011, 07:52:50 am »
is there an adapter for that "vga" plug? kinda looks like svideo to me. I plan on making a cab with a similar sized monitor.
madmatt
  • Last login:November 08, 2015, 08:47:54 am
« Reply #3 on: August 17, 2011, 10:02:35 am »
+1
I agree the "VGA" port look alot like an S-video out.  Please double check......
But from the details it claims to have one.
Good Luck
MM
« Reply #4 on: August 17, 2011, 11:42:27 am »
It comes with a VGA adaptor which plugs into the S-video port.  I'm thinking about pulling the trigger on this - it's $100 but I haven't seen anything cheaper (or easier to hook up to a computer).  I'd be interested in a broken portable DVD player but I don't know how to make the connection and most of those things only come in 16:9...
Blanka
« Reply #5 on: August 17, 2011, 11:44:16 am »
I'm wondering what a replacement iPad panel must cost. Damn those are sexy IPS 4:3 ones!
shateredsoul1979
  • Last login:December 22, 2011, 01:09:28 pm
« Reply #6 on: August 17, 2011, 01:11:20 pm »
looks like a dealextreme product
*edit* and so it is! http://www.dealextreme.com/p/8-tft-lcd-monitor-with-remote-controller-and-stand-640-480-32019
Did you find it for cheaper somewhere else?
« Last Edit: August 17, 2011, 01:13:31 pm by shateredsoul1979 »
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #7 on: August 17, 2011, 01:16:57 pm »
Some other annoyances to look out for:
Will the monitor automatically power on when power is applied after being off, or will it need the power button pushed?
Does it remember the last input? I have an RCA TV that needs to be reset using the remote if it's ever unplugged or there is a power outage to tell it to use the Svideo port.
ark_ader
  • I glow in the dark.
« Reply #8 on: August 17, 2011, 01:26:13 pm »
Laptops are perfect for small machines.
Look on Ebay for Thinkpad 240X.  Should be powerful enough for most emulators.
« Reply #9 on: August 17, 2011, 01:34:15 pm »
Yeah, but he could still use an external monitor with a laptop. Laptops have their own issues. How to power on, will the video ribbon cable be long enough to flip the laptop over, etc.
shateredsoul1979
« Reply #10 on: August 17, 2011, 01:38:51 pm »
If you're interested, I may have an ELO 15" touch screen and laptop base (I detached the lcd) I can sell you. Let me know if you're interested and I get get the details to you
