Author Topic: Is there a "most common" color of wooden stain conversion cabs  (Read 1711 times)
Generic Eric
I would like to match the color of the laminated wood grain on the generic conversion cabinets.  What would you say that color is?
~reworded~
« Last Edit: August 15, 2011, 04:37:55 pm by Generic Eric »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Is there a "most common" color of wooden stain conversion cabs
« Reply #1 on: August 15, 2011, 02:22:41 pm »
Old arcade generics? They weren't stained. They have laminate fake woodgrain.
NO MORE!!
Generic Eric
« Reply #2 on: August 15, 2011, 04:35:12 pm »
I went to the local hardware store.  I found a nice Pecan stain I liked...so much for matching the old generics.
« Last Edit: August 15, 2011, 04:46:48 pm by Generic Eric »
« Reply #3 on: August 16, 2011, 09:42:13 am »
By far the most common stain I have found in conversion cabs is called "water damage".
Blanka
« Reply #4 on: August 16, 2011, 09:58:47 am »
Most cabs have meranti (colour) veneer, and sometimes non pitted walnut.
« Reply #5 on: August 16, 2011, 12:05:14 pm »
I'd probably just go with something that you think will look nice in your house - matching it without a sample might be tough especially with a stain when you could get varying colors on something depending on how long you let the stain penetrate the wood, how many coats, etc.  I went with blue for mine!
Generic Eric
« Reply #6 on: August 16, 2011, 12:52:13 pm »
At the same time I bought the pecan colored stain, I bought a can of a pre-stain that is supposed to help even out the wood, chances are that was a waste of money though *shrug*
Anyhow.  I chose the pecan because it looked nice.  The plywood I have has two distinct shades.  Its going in the basement where the lighting isn't very good.
« Reply #7 on: August 16, 2011, 12:58:45 pm »
Pre-stain is ESSENTIAL.  Without it good luck trying to avoid splotches and a completely uneven stain.  Good thing you bought some!
« Reply #8 on: August 16, 2011, 01:13:32 pm »
....unless you are going for that handcrafted by a drunk sailor look.  ;D
On a side note, I had to reuse some old doors that had mold and water damage that planing couldn't even cure. I found very uneven staining does give a unique look that is really good to cover up very flawed wood. You have to go really thick in areas to make it work.
Keep and use the prestain.  :cheers:
