Author Topic: For Sale: Nanao MS9 15/24kHz relay switch kits. [UK - Int Shipping]  (Read 7409 times)
Franco B
For Sale. Nanao MS9 15/24kHz relay switch kits.
These switch kits allow you to change between 15kHz and 24kHz without having to manually having to move the plug on the chassis which can be a pain to get to.
I use mine in conjunction with a Ultimarc UVC when connecting my DC or 360 to my MS9 to display the games at 24khz. They may also be useful if you have 15khz and 24khz games that you switch between.
The relays have the correct JSTs pins and housings crimped on and simply plug into the chassis as shown below:
Note the ones I am making now don't have quick disconnects, they are soldered and are insulated with heat shrink. I just used quick disconnects for the prototype one.
With no power applied to the relays the monitor will run at 15kHz, if you power the relays with 12v the monitor will run at 24kHz. The relays can be powered from the Jamma edge from a pass though or from another 12v source.
The price of these are £30+ shipping. If I am doing more than one kit for people at once then I can do them for £25 each. I don't need to be doing two kits for you, It could be two kits between two people or whatever.
If you are interested feel free to reply or PM me. I am making a few kits up this coming week for people if anyone is interested.
« Last Edit: August 11, 2011, 08:35:04 am by Franco B »
Robinmasters
  • Last login:September 01, 2024, 07:04:10 pm
Re: For Sale: Nanao MS9 15/24kHz relay switch kits. [UK - Int Shipping]
« Reply #1 on: August 20, 2024, 06:28:48 pm »
Hello,
I'm very interested in this product.
Is it still possible to get hands on it?
Or even described somewhere to build one?
Thank you
christian_herculano
  • Last login:August 19, 2025, 02:27:20 am
Hi Franco B, I’d like to know if I’m still in time to buy a couple of units of the system you designed to switch frequencies on the Nano MS9. I recently acquired an arcade cabinet with this chassis and I’d love to implement what you developed. Thank you very much in advance.
