Author Topic: Could I use this monitors BNC connectors to accept groovymame output?  (Read 2380 times)
jimmy2x2x
http://www.expandore.com/product/Sony/Monitor/PVM14N6E.htm
I am currently using a RGB scart TV for my groovymame output, driven by an ATI card and was wondering if this monitor could be used with the RGB BNC's, it seems like it syncs on green, but also has an external sync input.
« Last Edit: August 10, 2011, 06:18:08 am by jimmy2x2x »
MonMotha
Re: Could I use this monitors BNC connectors to accept groovymame output?
« Reply #1 on: August 10, 2011, 09:12:45 am »
Looks like it will accept either SoG or TTL level composite sync (i.e. what arcades generally use).  There's a 4th BNC connector over by the RGB inputs that appears to be labeled "SYNC" in the blurry picture of the inputs.
Jack Burton
« Reply #2 on: August 11, 2011, 05:39:46 pm »
Here's the manual.
http://www.creativevideo.co.uk/pdf/sony_nseries_brch.pdf
You should be able to easily connect to this monitor and use it as an authentic arcade display.  You will need a VGA to RGBS cable like this one.  It's also called a VGA to 4 BNC cable.
Looks like they are on sale here:
http://www.deepspacecables.com/hd15_bnc.html
« Last Edit: August 11, 2011, 05:41:17 pm by Jack Burton »
