Author Topic: U360 balltop  (Read 2077 times)
neohusky
  • Last login:October 12, 2024, 06:48:52 am
U360 balltop
« on: August 02, 2011, 11:32:05 pm »
Hi all
I'm just waiting to receive my new U360s are the valorous generally universal. I'd like to change the factory red with these:
http://www.paradisearcadeshop.com/en/joysticks-trackball/213-seimitsu-lb-39-smoke-bubble-top.html
Are they compatible?
cammada
  • Last login:August 01, 2020, 10:59:21 pm
Re: U360 balltop
« Reply #1 on: August 03, 2011, 10:37:30 pm »
the ball top you mention in Paradise say it has 35mm ball top which is compatible to U360 but Ultimarc didn't mention anything about threading size where your ball top has 6mm threading. So you can email to Ultimarc and ask them about it.
Let me know how you go as I also want to change the ball top because I am aiming to make an illuminated ball top.... :)
neohusky
Re: U360 balltop
« Reply #2 on: August 04, 2011, 04:50:27 am »
Andy from Ultimarc just confirmed that the Seimitsu ball tops will fit the U360 stick.
Re: U360 balltop
« Reply #3 on: August 04, 2011, 04:55:17 am »
I already have my smoke bubble ball tops waiting for a couple of U360s to go on... Ah, anticipation...
bgmagic
  • Last login:January 14, 2014, 11:13:53 pm
Re: U360 balltop
« Reply #4 on: August 04, 2011, 09:52:23 am »
I ordered 4 different color Hard Candy balltops from GroovyGameGear.  They are 6mm.  I have a U360 and when I tried to put them on they started to screw on and I couldnt get them more than 25% of the way on.  When I look at the threads of the original ball and the Hard Candy balls they look the same but the Hard Candy ones almost look like they taper inwards as you look down the hole.  I wanted to know if anyone has any idea on this? My plan was to get 4 J-stiks (same shaft as U360) and use the Hard Candy balls (need Red, Blue, Yellow, Green).  If anyone has another idea on getting 4 switchable 4/8 way joys with those colored balls please let me know.
