Author Topic: Cocktail cabinet arcade build - my first 'real' project of any kind!  (Read 4797 times)
frotter
  • Last login:January 04, 2012, 11:28:29 pm
Hey All,
Well after lurking, reading and getting a huge amount of information from this forum, I thought I better post my first effort at building a MAME cocktail cabinet.
Anyway, a good mate of mine built a cocktail cabinet a few years back and I thought that would be a pretty cool project to give a go, so after biting the bullet I decided to give it a crack this year - and with a lot of people on this forum, the project is taking a loooong time as life has a habit of getting in the way!
Firstly, here is what I wanted to get out of my arcade machine:
1. A simple design - nothing fancy, just a decent looking cocktail arcade machine (not even sure if I will put any artwork/decals on it).
2. I wanted to include an extra control panel so that you could play 2 player games side by side (eg: 1941, Street Fighter, etc). I read all about the pro's and con's, but decided to go ahead with it.
3. I wanted to use a LCD monitor (again I read all the pro's and con's on this as well) as I will be using it as a normal computer from time to time and also plan to install a TV Tuner card in the computer that powers MAME, so it can function as a multipurpose device.
After deciding exactly what I wanted I spend a good few weeks doing a lot of design work. It felt like I was spending so much time designing it that I would never get around to starting any of the actual 'real work'! I look back now and am glad I spent a lot of time designing!
Right now I have done all of the woodworking (except for the top) and have built and painted the cabinet. I have also attached two control panels, but not the 2 player one yet. Last night I spent a few hours doing a lot of the wiring (I ended up using Cat5 cabling for the wiring as I would be able to make it 'look' neater once finished). It feels like I have learnt a heap of stuff from woodworking to building a computer from scratch and a lot about cabling and wiring, so it has been an awesome project to get stuck into.
Hopefully I will have it finished sometime in the next month or two, so I'll keep this updated with progress and photos. In the meantime here are some snaps of the build so far.
(I would appreciate any comment to hear what you think could be improved/changed/etc so if I ever do it again I could make it better).
Cocktail cabinet finally put together and painted with a undercoat/primer (no top yet) - it took a couple of months just to get to this point
The holes are for (from top left to top right): Power switch for whole cabinet, Power button for computer, switch for switching between control panels, Fan, 3 x admin buttons (Pause, Menu, Tab). The two holes at the bottom are for the power cord and an RCA jack to connect external speakers
Control panels all done and painted with an undercoat/primer. The CP are on a hinge so I can access the wiring easily.
Finally painted the cabinet and put one of the CP's on. The two holes on the near side are for the internal speakers and the hole on the same side as the CP is for another fan.
I made a mistake with the 2 player CP - the joystick mounting was to big for where I had drilled the joystick hole. I tried a couple of fixes, but no good, so I had to redo the CP top and rearrange the wholes for the joysticks and also the 'credit' button.
The Player 1 CP with the wiring done. I am going to tidy up all the wiring before I finish, but this was more a 'test' to make sure it was all going to work. Same with the inside of the cabinet - I promise it will be a lot neater when finished!
I'll post more pics and updates when I get around to it.
Thanks again to all the posters from this site - I have got so much information and help from reading people's post! THANKS!
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Cocktail cabinet arcade build - my first 'real' project of any kind!
« Reply #1 on: August 02, 2011, 10:42:55 am »
Are you planning on adding t-molding?
frotter
« Reply #2 on: August 02, 2011, 07:38:16 pm »
T-molding is something I want to put on as I think it would add a really nice finish to the build.
Thanks for the suggestion!
jimmy2x2x
« Reply #3 on: August 03, 2011, 01:48:06 am »
Looking great, keep us posted!
How did you fix the panels of the main body together, just glue?
frotter
« Reply #4 on: August 03, 2011, 02:21:12 am »
Hi Jimmy2x2x,
Thanks for the comment - it's been such a long process trying to find the time to plan and build this thing that it is great getting feedback like that!
Anyway, the cabinet is made from 16mm MDF and I put it together using plain woodwork glue, but also used a bunch of screws as well to give it some more strength.
Cheers.
« Last Edit: August 03, 2011, 02:23:56 am by frotter »
frotter
« Reply #5 on: August 15, 2011, 08:57:23 pm »
Been a while since an update, and I have had a fair amount of time to work on the cabinet, so it is getting pretty close to being finished - is it wrong to be feeling a little excited when you get this close to finishing a project!!
Anyway I have completed most things I just need to paint the cocktail lid and mount it, then cover it with a sheet of plexi/perspex to finish it off. And of course I need to finish configuring the computer with MAME.
Also, what do people recommend in terms of a front end. I am split between Hyperspin and MaLa. Any pro's / con's would be appreciated.
A shot of a few of the plans I made for the build. I know I went overboard with the design, but that is just me!
The cabinet with all control panels attached and most of the iPac wiring completed. It was great to see that all of the buttons and joysticks worked first time! I got all the grounds, wiring, etc right! That was a massive relief.
This is a shot of the back panel. There are a number of 'admin' buttons, but my favorite is the switch that can toggle between the control panels. This will enable me to only have either the vertical of horizontal ones functioning at any one time to avoid people playing with buttons or joysticks and interrupting game play.
I had to have a bit of a play of one of my all time favorite games, 'NBA Jam'. Lots of fun!
Cutting the top out with the jigsaw.
The top sitting on the monitor. I just need to paint it black and then mount the monitor underneath it.
It is all getting very close now!
muttieb
  • Last login:July 31, 2012, 04:34:53 pm
« Reply #6 on: September 01, 2011, 08:23:18 pm »
Looking good. What size and kind of monitor are you using
frotter
« Reply #7 on: September 01, 2011, 11:41:02 pm »
Thanks for the comment. The monitor I purchased was a ACER 21.5" (Model V223HQBD). It works really well. The one thing I did find was that on side with the two players the angle meant the screen was very washed out and I didn't know what to do. In the end I read somewhere that turning the monitor upside down you get a lot better viewing angle, so I tried that and it works. The viewing from the two player side is now perfect.
I have also nearly finished. The top has gone on and the perspex/plexi is done. I am just tidying up the software side of things with Hyperspin and CPWizard and it will be done. I'll post some final pics this weekend.
The last thing will be to decide on some artwork to put on top. Something very simple and minimal. One idea was to have a Pac-man in one corner and in the opposite corner a Ghost with power pellets around the edges. Does that sound ok?
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
« Reply #8 on: September 01, 2011, 11:49:11 pm »
very nice  :applaud: :cheers:
