Author Topic: Help removing banner/bezel?  (Read 3215 times)
mbird59
  • Last login:August 08, 2011, 02:25:45 pm
« on: July 31, 2011, 04:59:28 pm »
Hi,
I am not sure what it is called but there is a banner or bezel saying something like "NEOGEO featuring SNK ...." at the top of Metal Slug 5 when I run it. I have gone into mame config vis the mala configuration dialogue abd turned off bexels, additional artwork etc. and it does not seem to have any effect.
Is it possible to run Metal slug without this banner at the top and if so can someone tell me what I have to do?
Thanks,
Mick
loadman
  • Moderator
    • MaLa
Re: Help removing banner/bezel?
« Reply #1 on: August 02, 2011, 06:58:49 am »
Sounds like a Mame question really.
All MaLa does is act as an editor the mame.ini file.
I would look at options in that file and ask the mame people
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #2 on: August 02, 2011, 09:59:07 am »
Are you using any other programm that could show a bezel...like cp viewers?
br2000ad
  • Last login:March 22, 2013, 03:55:09 am
« Reply #3 on: August 31, 2011, 02:35:43 pm »
Hi,
Thanks,
Mick
load up a game in mala and press the tab button to bring up setting you can hide bezels...i,ve only set mine up the other day,you don,t know how to sort layouts out do you...?
MTPPC
« Reply #4 on: November 11, 2011, 02:50:38 pm »
I thought the bezel was programmed in to play horizontal games on a vertical display. If there is a setting that gets rid of it and expands the game, that would be great.
http://pinballmd.com/
