Author Topic: Keystroke issue  (Read 4826 times)
sprtm
  • Last login:May 20, 2014, 07:17:22 am
Keystroke issue
« on: July 08, 2011, 06:21:15 am »
Hi all, after searching around I found this topic http://maximusarcade.com/phpbb/viewtopic.php?f=3&t=1121&start=30 which seems similair to my issue.
Everytime I start a MAME game that produces an error, "xxxxx.chd NOT FOUND", black screen etc., MA (2.10) won't register any keystrokes when back in the MA menues again - restarting MA does not help, to power off/on the PC is the only solution I found so far.
As I have the Ipac programmed on the fly I thought something went wrong there when returning back to the menues, but if I open Notepad I can see it's still programmed correctly, it's just MA not registering the keystrokes (same with the USB keyboard).
If I skip the Ipac programming when opening/closing the emulators the issue does not occour, but that mean I can only use one Ipac layout which is bad.
Does anyone know a solution or a workaround?
Many thanks.
Edit:
Two more examples I just found:
http://forum.arcadecontrols.com/index.php?topic=110330.0
http://forum.arcadecontrols.com/index.php?topic=112655.0
« Last Edit: July 08, 2011, 06:25:31 am by sprtm »
