Author Topic: Mortal Kombat II Mame Monitor Issue  (Read 1742 times)
  • Last login:Yesterday at 04:38:46 pm
« on: July 04, 2011, 09:34:00 pm »
So I finally had some time to work on the MKII cabinet and the monitor still has 2 issues:
  • The monitor does not fill the screen horizontally. I have some static black borders that I can't fill
  • When I select some games, the VSync is off. If I fix the Vsync for that game, the other games Vsync is off
Is this something simple or does anyone have an idea what the problem is? I'm using a ArcadeVGA and my default res is 640x480. I followed the instructions on Ultimarcs website and made the changes to my MAME.INI that I need to. Attached are some pics of the monitors black bars. The black bars are on the left and right and are equal in size.
  • Last login:December 02, 2025, 03:23:14 pm
Re: Mortal Kombat II Mame Monitor Issue
« Reply #1 on: July 05, 2011, 10:21:16 am »
You've adjusted the H-width?
« Reply #2 on: July 05, 2011, 11:29:47 am »
As far as I can tell, there isn't a H-width.  :dunno
There is a little white control panel for monitor controls and H-width isn't on it.
« Reply #3 on: July 05, 2011, 11:31:44 am »
Have you looked elsewhere on the chassis?  Sometimes all the controls aren't all together in one spot...
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #4 on: July 07, 2011, 01:35:04 am »
What model of monitor are you using?  Is there a manual?  There may be a combo of buttons or a "service mode" to adjust H-width?
« Reply #5 on: July 07, 2011, 08:53:24 am »
Haruman hit it on the head. There is a monitor width adjustment coil I need to tweak. You can read more about it here:
http://www.neo-geo.com/forums/showthread.php?225952-Has-anyone-adjusted-a-horizontal-width-coil-on-an-arcade.&p=3219988
http://playchoice.riemen.net/rep_monitor_width.html
