Author Topic: USB power from Laptop - will this work?  (Read 2315 times)
Evetsllub
  • Last login:February 10, 2012, 03:09:32 am
« on: July 04, 2011, 09:20:27 pm »
Hey guys,
I have a few things that need to run through USB.  A laptop will be running everything, and i'd like to get away with a passive USB hub if possible to avoid wiring more stuff to a power supply (space is limited, see "Cafe au Cade" project in the projects thread for an idea, it all needs to fit under a coffee table).  Plus I have a nice and compact 4 port passive USB hub that i can use.
This is what i need to run through USB:
2 x Ultimarc U360s
1 x Ipac 2 keyboard encoder
1 x USB powered 860w speakers - http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150600149748#ht_4325wt_888
2 x USB ports that will have external access... to hook up keyboard/mouse/USB stick or anything like that.
What do you think, am i risking frying the laptop running all of this stuff?  The main issue i imagine are the speakers as the other stuff wont be drawing too much power i wouldn't think.
BobA
  • What Me Worry?
Re: USB power from Laptop - will this work?
« Reply #1 on: July 04, 2011, 09:43:12 pm »
Should have no problem with your list but I seriously doubt that those are 860W speakers.   USB would have a real problem with them if they are.
Evetsllub
« Reply #2 on: July 04, 2011, 10:04:44 pm »
yeah i thought the same thing... just some marketing BS.
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #3 on: July 05, 2011, 01:08:34 am »
marketing BS??? hell, they aren't even trying. but 860 watts "PMPO"????? (supposedly "peak music performance output") is that into a dead short output for 10 cycles then???... lets see... about a trilliosecond??
MonMotha
« Reply #4 on: July 05, 2011, 06:03:18 am »
I think they're saying that their speakers are as loud as if you were to dump 860W (actual, RMS watts) into a resistor.
Blanka
« Reply #5 on: July 05, 2011, 06:16:54 am »
ROFL!!!!!
How does THAT work? 5V @ 500ma means a maximum output of 2.5W RMS. To get 860W......
Does it have a electronic flash capacitor getting to full power, with just 1 chance to release it in 1 ms to the speaker cone, blasting the unit entirely in small pieces?
« Reply #6 on: July 05, 2011, 07:36:46 am »
 :laugh2:
Yeah, Note that the ad never says they're 860 watt speakers (as far as I can tell), but rather that designation seems to be used as a "model number" or somesuch.
Those little usb powered speakers are pretty much worthless. I've never heard a pair that sound good.
I'd find a pair of decent amplified speakers without a sub (Logitech, Bose and Altec Lansing sell pretty good ones, and you can usually find deals online for less than 50$).
Evetsllub
« Reply #7 on: July 05, 2011, 09:02:34 am »
the sound doesnt have to be real good.  space is seriously limited, people playing this arent going to be saying 'damn i wish the sound was better'.  they should do the job.
