Author Topic: Kustom Mortal Kombat 9 Kab  (Read 6517 times)
derep
  • Last login:July 12, 2011, 05:58:52 pm
« on: June 27, 2011, 02:33:48 pm »
So MK9 recently came out and this revival of the MK2-3 era with modern graphics /combo system was irresistible.
I bought it and have been playing for the past couple months and its sparked an old interest in getting a arcade machine.
I was checking local Criagslist for "arcade" related items and within 2 weeks i stumbled on to a free cab that someone was getting rid of.
My first score on craigs! lol
I've got a xbox360 and recently bought a 24" asus lcd.
there is a company that makes a adapter for xbox usb to arcade controls but they are out of stock at the moment. So ill have to wait for that part.
Eventually i will add a PC & HS/Emulators. Is there any advice on how i should wire up the arcade controls so it will be easy to add the PC support later ?
Heres some pictures of the cab, it needs some sanding, paint,new control box, and some additional wood framing.
So far i've found a good position for the monitor and made a mount.
I started working on the control box too, and will update as i go.
« Last Edit: June 27, 2011, 02:35:33 pm by derep »
  • Last login:December 02, 2025, 03:23:14 pm
Re: Kustom Mortal Kombat 9 Kab
« Reply #1 on: June 27, 2011, 02:43:00 pm »
You can also used hacked controllers to connect your controls.   :cheers:
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: June 27, 2011, 02:53:46 pm »
Yup, just hack the controllers.
derep
« Reply #3 on: June 28, 2011, 12:04:06 am »
I've thought about this route, there is very little price difference to go with the pcb vs buying 2 controls and spending time to solder the crap out of em.
Pcb will be a bit cleaner and ill be able to hook up my ps3 if needed as well  ;)
Here is what i got done on the control board so far.
Need some art and plexi 34x14
Also wondering what to do about cleaning up all the edges on the whole machine, looks like previous owner used bondo or spackle
« Reply #4 on: June 28, 2011, 09:45:55 am »
What PCB?
Donkbaca
« Reply #5 on: June 28, 2011, 11:43:15 am »
You can get 2 SFIV madcatz pads for about 50 bucks, it takes about an hour to hack them if you have never done it before.  I don't see why you would want both a PS3 and a Xbox and a PC in your cab; I can't think of anything that would play well with arcade controls that is available on the PS3 that isn't available on the Xbox, not to mention that the pcb isn't MS certified, and could get zapped by an update, and they have been out of stock for a while...
Anyhow  good luck with the controls.  Make sure you document what you do....
derep
« Reply #6 on: June 28, 2011, 11:53:02 am »
What PCB?
 Akishop PS360 pcb
Hour each ? do you have a link to a good how to site ?
where you get 2 madcatz pads for 50 ?
I have more games for ps3 then xbox, only duplicate im gonna buy is mk9.
« Last Edit: June 28, 2011, 11:57:07 am by derep »
Donkbaca
« Reply #7 on: June 28, 2011, 12:11:54 pm »
I have heard lots of good things about the akishop pcbs, but from what i gather there is a redesign coming and they are out of stock, and have been so for a while.  I decided to go pads because: 1) Didn't want to wait for them to be back in stock; 2) so no use in the ps3 connectivity and 3) thought they were too expensive.
The pcb is designed to be put in custom fight sticks, so they can be universally compatible, so they only support 1p each.  So for a 2p cp you would need two of them.
I got my pads from vpgames.com, they were like 23 bucks each I think.  You can find good info on how to hack them on shoryuken.com, or you can pm me or haruman for advice.  Its a pretty straight forward solder job, its a common ground pcb, so all you need is to solder the positive leads and a ground or two.  I even soldered mine up so that the guide button lights up when the controller is on.  All the inputs are digital, so no digital/analog conversion is necessary.  The only tricky thing is soldering the guide button, since the spot is tiny.  If you look on my project thread, you will see what they look like.
You probably have more PS3 games, but most of them you probably won't want to play on your cab.  Most games these days use analog controls, and won't work well with the digital joys you have in your cab.  In terms of Cab-friendly games, the xbox is better because there are a lot of good xbox live arcade games that play well, plus the shmups.
« Reply #8 on: June 28, 2011, 12:48:44 pm »
Pfft.  That guide button is easy (at least when you've done hundreds of these things...   ;))
Anyway, yeah, if you decide to try it, give one of us a shout.
Donkbaca
« Reply #9 on: June 28, 2011, 01:10:11 pm »
You could probably have them shipped to Haruman, have him hack them for you and ship them back to you for less then the cost of 2 akishop PCBs
« Reply #10 on: June 28, 2011, 01:12:22 pm »
I actually have 2 in stock already from VP games.  I tend to buy at least 4 at a time, that way I get the free shipping.  :cheers:
« Reply #11 on: June 28, 2011, 01:13:41 pm »
How much is an Akishop PCB?
derep
« Reply #12 on: June 28, 2011, 01:15:10 pm »
Is this the one your talking about for 22 ? http://www.vpgames.com/p-3512-mad-catz-officially-licensed-controller-for-xbox-360-pc-gaming.aspx
Does it matter if it has 4 buttons or do i need the 6 button one ?
Im not quite decided on what to do for a button layout yet. I would like to go with the MK but not sure how big of a deal it will be with other games
akishops are 44 each, so its close
« Last Edit: June 28, 2011, 01:17:37 pm by derep »
Donkbaca
« Reply #13 on: June 28, 2011, 01:21:01 pm »
UPDATE 6/15/2011: We are not taking any more preorders for the PS360+.  Akishop has announced that release of the PS360+ will now occur during Q3 (July-September).  We will resume offering this product when restocks are available.  Akishop informs us that they are redesigning and adding features to the PS360 Tri-Mod PCBs, renaming them the PS360+.  Anticipated shipment date is now dependent on the manufacturer.  All preorders and replacements will be honored with the PS360+ once the products are available at our store.
That is from focusattack.com  The list for the pcbs was 54.99, they reduced them to 44.99, who knows how much the new ones will be, or when they will be out.
Derep:  this the one you want:
http://www.vpgames.com/p-3724-mad-catz-xbox-360-street-fighter-iv-controller-sf-4-turbo-fightpad-assorted.aspx
at 23 bucks a pad, its a REALLY good deal for that pad, when they first came out they were like 40 bucks each, and are by far the easiest to hack pads out there.
I stumbled upon VP games when I was making my aimtrak guns, I got these for my shells: http://www.vpgames.com/p-6290-ps2-psx-mini-light-gun-w-usb-port.aspx  and they were like 6 bucks each at the time.  I have ordered from them several times, they ship fast too.
derep
« Reply #14 on: June 30, 2011, 10:31:09 am »
Started playing with side art and marquee
The sides will probably change when i figure out whats going on the control board
Donkbaca
« Reply #15 on: June 30, 2011, 12:18:48 pm »
You gotta go Scorpion - Subzero....
derep
« Reply #16 on: July 01, 2011, 10:54:11 pm »
Too standard. Im thinking keep Raiden and switch Sub to Liu kang
or reptile if i can find some good art.
derep
« Reply #17 on: July 12, 2011, 03:45:15 pm »
Got my speaker system in yesterday, bought a used set on ebay for 70. These speakers are awesome :cheers:
Klipsch promedia 2.1
mk9dreamz
  • Newbie
  • Last login:August 17, 2011, 06:43:23 am
« Reply #18 on: July 14, 2011, 04:48:28 am »
Hi derep
I am coincidently busy with the same type mk project  :cheers:
We can maybe work together to share project specific tips & ideas etc.
You can contact me via skype, my ID: NZufologist
