Author Topic: Master button for power?  (Read 2006 times)
NatasNJ
  • Last login:December 19, 2003, 04:10:03 pm
« on: September 03, 2003, 10:12:44 am »
http://www.newegg.com/app/Showimage.asp?image=11-129-118-10.jpg/11-129-118-02.JPG/11-129-118-03.JPG/11-129-118-04.JPG/11-129-118-05.JPG/11-129-118-06.JPG/11-129-118-07.JPG/11-129-118-08.JPG/11-129-118-09.JPG
(Link fixed by Moderator)
Here is a link to my computer Case in my MAME cabinet.  I have everythign setup to turn on once my PC is turned on.  (have that special surge protector)  I don't seem to have a (keyboard power on option), so I guess my only option is to wire the power button from the case to somewhere else?  Or is there a better option?  I just don't want to have to bend over and around the back of my cabinet to turn this on eveytime.  I would like to mount a switch or button the the front area or the side.
Thoughts?  Ideas?  Suggestions?  Which buttons should/can I use?  How do I wire it?  Etc..
« Last Edit: September 03, 2003, 11:01:05 pm by JustMichael »
TalkingOctopus
    • My Arcade
Re:Master button for power?
« Reply #1 on: September 03, 2003, 10:45:29 am »
Any pushbutton will do.  My power button is an arcade pushbutton button.  Simply attach the current power button wires (found on the motherboard -- it will say pwr sw) to the new button.
NatasNJ
« Reply #2 on: September 03, 2003, 10:53:22 am »
So this will work?
Part # 54-0004-20 from www.happcontrols.com ?
And if so...  How do I go about wiring it to my motherboard?  What type of wire?  Can I just cut the current power button connector wires and lengthen them to reach this new button?
That should work right?
TalkingOctopus
    • My Arcade
« Reply #3 on: September 03, 2003, 11:01:24 am »
So this will work?
Yeah that would be fine.
What type of wire?
20-22 gauge or whatever you used to wire your cp will work.
Yes you can
NatasNJ
« Reply #4 on: September 03, 2003, 11:09:29 am »
You da MAN!
I bought a prebuilt CP.  So this will be the first wiring I will be doing on my cabinet.  (excluding the power cord wired to my marquee light)
Thanks...
Chris
    • Chris's MAME Cabinet
« Reply #5 on: September 03, 2003, 01:55:52 pm »
You don't even need to order from Happ.  Any momentary pushbutton from Radio Shack will do... heck, a doorbell button from Home Depot will work!
--Chris
--Chris
NatasNJ
« Reply #6 on: September 03, 2003, 05:37:28 pm »
Yeah but the push button from happs is a cool illuminated one.  Doubt you could get that from RadioShack.
All about the look baby!!!!:)
Krynos
  • Last login:March 06, 2007, 07:13:35 pm
« Reply #7 on: September 03, 2003, 06:55:35 pm »
I just used a red ultimate button from Happ for my PC's power, hacked into the exisiting wiring.
One press and the smartstrip does the rest!
- Krynos
NatasNJ
« Reply #8 on: September 03, 2003, 08:47:45 pm »
Krynos, Could you post a picture of your power button setup?
And one of full machine.  Would like to see how that looks.
Thanks..
TalkingOctopus
    • My Arcade
« Reply #9 on: September 03, 2003, 08:53:15 pm »
Here is a picture of my setup, although you it is a little difficult to see the details -- it is the same setup as krynos.  The red button turns on the computer and everything else except the tv via the smart strip.
NatasNJ
« Reply #10 on: September 04, 2003, 07:25:21 am »
Is the back of your cabinet easily accesible?  Looks like a pain to reach around each time you want to turn the cabinet on...
I know my unit would suck if I had to reach around everytime.  I just am still trying to decide where to install my button.
TalkingOctopus
    • My Arcade
« Reply #11 on: September 04, 2003, 09:34:25 am »
To turn it on, I have to bend down and press the button.  There is just enough room between the wall and the cab for my hand.  I purposely made it a little difficult to turn on.  You can put your power button wherever you like.
jets
  • Last login:February 25, 2005, 06:40:39 pm
  • all your base are belong to us
« Reply #12 on: September 06, 2003, 09:56:17 am »
I have done the same thing but shutting down has proved to be a PITA. I set the PC to shutdown when I press that same power button but gamelauncher hangs and I get the "ending program" dialog which kills the experience. Any ideas on a better way to use the power button to do a super fast shutdown?
TalkingOctopus
    • My Arcade
« Reply #13 on: September 06, 2003, 01:05:30 pm »
If it really bothers you, use mamewah instead of gl.  Mamewah does not have that problem.  However, you still will get the windows shutting down dialog boxes ect...
