Author Topic: Joystick under-mounting (hiding bolts)  (Read 3573 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: June 23, 2011, 09:50:08 am »
I routed out an area under my control panel for my joystick and just realized that I will need to drill holes to keep the joysticks attached to the control panel.  I have a woodgrain finish and would like to try and hide the bolts if possible. I was thinking about countersinking the holes except that the control panel is already stained the and the first coat of polyurethane has been applied.
Any ideas?
« Last Edit: June 23, 2011, 09:55:30 am by emb »
jimmy2x2x
Re: Joystick under-mounting (hiding bolts)
« Reply #1 on: June 23, 2011, 09:56:57 am »
Use an insert, like these http://www.davart.co.uk/inserts-multibarb.htm - drilled and mounted into the underside of your CP.
DrChek
  • Last login:August 06, 2025, 01:09:15 am
« Reply #2 on: June 23, 2011, 09:58:59 am »
emb
    • Don Honerbrink
« Reply #3 on: June 23, 2011, 11:26:34 am »
Those look like they will work perfectly! Wow...7 bucks for a couple pieces of metal... Thats quite a profit margin.
emb
    • Don Honerbrink
« Reply #4 on: June 23, 2011, 11:30:31 am »
Looks like groovygamegear sells mounting kits for about 5 bucks
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: June 29, 2011, 08:00:12 am »
Indeed. Why I decided no on that.
-Banned-
