Author Topic: Daphne error while using MALA  (Read 3332 times)
Indyplumber
  • Last login:November 19, 2012, 09:46:03 pm
« on: June 22, 2011, 12:34:49 am »
I've spent all night trying to get daphne to work with MALA.
I can start Dragon's Lair with the batch file just fine or I can start it with DaphneLoader just fine.
But when I go into MALA to launch it I get the  error:
Could not load bitmap: pics/led0.bmp, pics/led1.bmp, etc......
I have the exe blank
The rom path points to the dir my batch file is in.  Extension is set to bat
The command is set to "%path%\%rom%.%ext%"
Any ideas on this one?  I did a forum search and found nothing
« Last Edit: June 22, 2011, 07:08:10 am by loadman »
Indyplumber
Re: Daphne error in MALA
« Reply #1 on: June 22, 2011, 12:46:56 am »
My batch file is as follows:
@echo off
"c:\emulators\programs\daphne\daphne.exe" lair vldp -framefile "c:\emulators\programs\daphne\framefile\dl.txt" -fullscreen -nohwaccel -latency 300
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
« Reply #2 on: June 22, 2011, 12:49:53 am »
Those sound like Daphne errors, not MaLa errors. I have Daphne and MaLa set up with bat files, no problem. I can give you specifics on how, but probably not for a day or two.
Indyplumber
Re: Daphne error while using MALA
« Reply #3 on: June 22, 2011, 09:49:33 am »
I fixed it.
My Batch file read:
@echo off
"c:\emulators\programs\daphne\daphne.exe lair vldp -framefile "c:\emulators\programs\daphne\framefile\dl.txt" -fullscreen -nohwaccel
I changed it to read:
@echo off
cd c:\emulators\programs\daphne
"daphne.exe" lair vldp -framefile "c:\emulators\programs\daphne\framefile\dl.txt" -fullscreen -nohwaccel
now MALA loads it just fine
