Author Topic: How to bring up game selection window after exiting a game??  (Read 5113 times)
HanoiBoi
Wow, I hate posting a question like this, but I’m running a little short on my trial period…
My MAME cab recently lost its hard drive and I’ve built it up again from scratch.  I’m looking into Maximus Arcade as a Front End.  I like most of what I’ve seen, but I can’t quite figure this out; when I’m in a game, I want to exit the game and go back to the game selection menu.  When I press my 1P and 2P Start buttons simultaneously, it closes the game as I’m expecting, but it doesn’t quite get me back to the menu.  Instead, I’m shown a blank screen.
From here, I can press Ctrl+Alt+Del and it basically flushes through and then the game selection screen appears (along with Task Manager, of course).
Do I have something configured wrong?  How can I exit the game and (quickly) display the game selection menu?
metallimaniac
  • Last login:March 22, 2012, 05:11:08 pm
    • DebugStation
Re: How to bring up game selection window after exiting a game??
« Reply #1 on: June 22, 2011, 04:33:46 pm »
I would try holding your P1+P2 start buttons for about 3 seconds or so. I remember having to do this for one of my button combinations. Hope this helps.
postmortem
  • Last login:July 03, 2020, 10:58:40 am
« Reply #2 on: June 22, 2011, 10:40:28 pm »
make sure scroll lock and num lock are off when you exit the game and you shouldnt have an issue
Cabs: Tron, MKII, MK4, KI2, Blitz99, TMNT, Pac-Mania, Defender, Mame Box.
PCBs: MK1, UMK3, Killer Instinct, Area51, Sunset Riders, Pit Fighter, Wargods.
Pins: Bride of PinBot, Attack from Mars, The Shadow
HanoiBoi
« Reply #3 on: June 23, 2011, 12:12:46 am »
Thanks for the ideas guys.  Unfortunately, neither solved my issue.
postmortem
« Reply #4 on: June 23, 2011, 03:10:44 am »
the only time mine does this is if i exit the game using escape. I have mine set so holding start for 5 seconds exits the game and if i exit that way i never have any problems.
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
« Reply #5 on: June 23, 2011, 03:30:15 pm »
When i was working with MA, i had to press P1 + P2 twice in some circumstances to get back to the lists
Encryptor
  • Trade Count: (+34)
« Reply #6 on: June 23, 2011, 04:50:11 pm »
HanoiBoi
« Reply #7 on: June 25, 2011, 03:47:05 pm »
Thanks for the replies.  I'm not sure what I have in "Quit Executable", but I know that I came across that field before and intuitively assumed that the executable meant the entire front end, not to just exit the currently loaded game.  I'd almost bet money that the docs didn't describe it as otherwise.
At this point, I think I'm just going to go with HyperSpin.  It looks good, and the interface seems a bit more intuitive to me....especially being familiar with HyperPin.
Encryptor
« Reply #8 on: June 25, 2011, 05:40:29 pm »
The quit frontend is on the next page. That setting is for quitting the game you're playing I believe.
BobA
  • What Me Worry?
« Reply #9 on: June 26, 2011, 09:54:27 am »
Use the end key to exit the game as spec'd by ma.  If you use ESC or a combination of keys for ESC it just gets lost.
Kokapetl
  • Last login:July 29, 2020, 12:59:49 am
« Reply #10 on: June 26, 2011, 11:47:03 pm »
I've noticed escape causing problems too. I think what happens is that when you use escape to exit, then the escape send messages to maximus and the emulator to close and it can get lost for one of them. If you assign it to something like 'end', then maximus can force the close of the emulator and then deal with it properly without it tryign to terminate itself. I may be wrong, but this is my reasoning as to why escape seems to have problems.
jimmy2x2x
« Reply #11 on: June 27, 2011, 01:40:17 am »
I use 'P' to exit the game - specifying a delay of 2 seconds
So when I tap P the game pauses, tap again to unpause.
Hold P to quit.
Works well for me and gives me 2 useful functions for 1 button on my CP, this is the only admin button my CP.
