Author Topic: Mounting de-cased TV in metal cabinet  (Read 2017 times)
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« on: June 21, 2011, 07:53:38 am »
Hi all,
I've done some work with arcade monitors but this is my first time mounting a decased TV.  I've got an old metal nintendo cocktail that I'm doing up and I'm mounting a decased 14 inch tv.  I've discharged it and mounted the chassis to a block of wood.  I'm intending on mounting the tube to the metal frame.
In all the examples I've seen the tv is always mounted to wood and I was wondering if there were any additional safety precautions to take when mounting to metal?
The metal mounting tabs are safe, correct?
Do I need to put some rubber/plastic between the tube and the metal frame?  Between the mounting tabs and the frame?
Essentially, what are the items I need to keep away from the metal case?  I'm assuming the anode cap and wire are the only bits I need to keep away specifically but I'd rather check with those experts here.
Do I need to do anything extra to ground it?  My limited knowledge would suggest that I shouldn't be.
It's a two prong plug for the tv if that makes any difference.
Thanks for any help..
PS - I should also add that the bottom of the neck board comes quite close to the bottom of the case.  Should I be insulating the bottom of the board (ie plastic sheet on the bottom of the case below the neck board)?
« Last Edit: June 21, 2011, 07:56:09 am by wweumina »
Re: Mounting de-cased TV in metal cabinet
« Reply #1 on: June 21, 2011, 09:36:00 am »
You're probably going to need to build some sort of frame for the CRT.  Monitors are mounted in a metal frame that mounts to the cabinet.  It doesn't just mount to the cabinet with the CRT tabs.
If it helps here is a link to some pics of how my son and I mounted a VGA CRT in a Berzerk cabinet.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: June 21, 2011, 03:11:54 pm »
i own some metal universal cabinet made by adp germany and sega /namco japan. first thing i can tell is each metal part of it is grounded , no matter if its the main cab , a hinge ,the monitor mounting frame or the coindoor. the screen is directly mounted in a frame without isolation . make sure the chassis is insulated properly and if the neckboard is very close to the backside isolation sheet of plastics arent bad either . hantarex use em to isolate the neckboard , sega naomi to isolate the entire tube and chassis area.  double check all wires are undamaged and fixed.  pay special attention to any movable parts like doors , rotating frames or cables touching sharp edges. for example the degauss wires can be damaged by remounting a tv. i once had an ok baby cab ( china stuff ) , nearly new without a rubber plug on the 220 volt metal plate entrance of the power cord.
« Last Edit: June 21, 2011, 03:16:27 pm by apfelanni »
