Author Topic: Kortek KT-2914F schematic???  (Read 7852 times)
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« on: June 20, 2011, 01:21:09 pm »
Does anyone have or know where I can find a schematic for a Kortek KT-2914F monitor?
grantspain
Re: Kortek KT-2914F schematic???
« Reply #1 on: June 20, 2011, 03:38:42 pm »
pm me your email and i will send one across ;)
MonMotha
« Reply #2 on: June 20, 2011, 04:38:18 pm »
It's small enough to just attach it to this post, so here it is in case anyone ever finds this thread looking for it.
Karetaker
« Reply #3 on: June 21, 2011, 12:57:47 pm »
Thanks guys I REALLY appreciate it!!! But, that's the one I have and it doesn't seem to be the same as the board layout. IC201 got cooked and baked some resistors as well. It is pretty damaged and some of the traces need repaired. A couple resistors are so cooked I can't tell what they were. The schematic compared to the board layout just don't seem to jive.
Karetaker
« Reply #4 on: June 23, 2011, 02:11:56 pm »
It looks  to me like the schematic and parts list are both for another monitor. Does anyone have one of  these monitors? I'm looking for the values of R206, R210, R212 and where the pins of IC 201 go.
MonMotha
« Reply #5 on: June 23, 2011, 03:43:04 pm »
While I've not done extensive work, the schematic/parts list seemed at least reasonably correct when I was looking at mine.  You sure it's a KT-2914F?  I wonder if there were two different monitors to bear that model number or something...
Karetaker
« Reply #6 on: June 27, 2011, 01:52:11 pm »
That's what the sticker says on the monitor.
MonMotha
« Reply #7 on: June 27, 2011, 06:24:44 pm »
Here's another one I have for the KT-3414DF.  It's the 34" version, but it's a similar monitor.  The circuit looks similar, at least, but maybe there are differences, and this may be closer to what you have; I don't know.
Is it maybe possible that someone's replaced the chassis on your unit?  Can you snap a picture?  I'd recognize a 2914 immediately.
Karetaker
« Reply #8 on: June 27, 2011, 08:05:57 pm »
No problem... here you go:
MonMotha
« Reply #9 on: June 27, 2011, 08:28:50 pm »
Yep, looks like what I've got...
