Author Topic: Mame.exe window and taskbar show up on game start  (Read 2534 times)
jukingeo
  • Last login:March 14, 2015, 08:25:28 pm
« on: June 19, 2011, 10:17:05 pm »
Hello All,
I am running Mala version 1.05 on an older Compaq computer and I had noticed that when you start up a game on the list, for a brief moment (about 1 or 2 seconds) you see a black bordered window with a top label that says "C:\Mame\Mame.exe".   Also the taskbar shows up in that same time.  Then you are taken to the MAME nag screens that have you 'move the joystick'.   I believe I have disabled this function in mame.ini, but it still seems to persist.
Since this computer is going in a cabinet, I find this annoying as I would like to remove all traces of Windows as possible.   It would seem that a good fix would be to have the Mala window stay on top.   Would anyone know how to fix this?   It is happening on my main computer as well, as I also tested it there.
Thanx,
Geo
"Let me tell you about the time I used a sharpened clamshell to turn a T-Rex into a T-Rachel!" -Buck  Ice Age 3
loadman
  • Moderator
    • MaLa
Re: Mame.exe window and taskbar show up on game start
« Reply #1 on: June 20, 2011, 06:06:07 am »
There are options in MaLa on the Mame tag to 'Hide' the DOS screen.
Options - Mame config - basics - Dos Window State
Try that
jukingeo
Solved: Mame.exe window and taskbar show up on game start
« Reply #2 on: June 20, 2011, 11:00:08 pm »
Try that
Gotcha...that did the trick.
Thanx!
Geo
