Author Topic: SEGA Original Seal circa 1985  (Read 9740 times)
SavannahLion
« on: June 13, 2011, 04:21:38 am »
I was a little mystified on a spot on my cabinet where something was clearly ripped off. I have the FCC and Serial tags accounted for and am now in the process of getting the FCC sticker reproduced. Reading the manual for some wiring details tonight and realized what the missing sticker might be.
Unfortunately, the PDF scan looks like ---steaming pile of meadow muffin--- (as you see). So anyone with a SEGA cab have a better image for me to work off of? If it's metallic, I might still have time to shoehorn a reproduction with Etienne before he sends the sheet off to the printers.
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
Re: SEGA Original Seal circa 1985
« Reply #1 on: June 13, 2011, 09:21:28 am »
I've seen them in manuals, for example page 5 of Golden Axe here:  http://www.emuparadise.org/MAME/manuals/arcade/goldnaxe.pdf
I don't know if you'd be happy to shop one from a different game like that?
« Last Edit: June 13, 2011, 09:23:45 am by Corbo »
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
SavannahLion
« Reply #2 on: June 13, 2011, 11:00:06 am »
Once again, I am amazed at the varying qualities of the scan out there.
But I digress. Yeah, that looks like what I want, but what is it? A sticker? A metal tag? How big is it?
OK I know it's a sticker. But that's about all I know about it really. The image I have seems to show a hint of something extra embedded in the label. Maybe some sort of water mark I guess.
Mr. Do
  • Last login:March 04, 2024, 12:56:39 am
  • MAME Art Editor
    • Mr. Do!'s Arcade
« Reply #3 on: June 19, 2011, 05:47:18 pm »
Take a look at the Turbo bezel from the MAME artwork to see what you are looking for.
RELAX and just have fun.
Remember, it's all about the games.
Mr. Do!'s Arcade
SavannahLion
« Reply #4 on: June 20, 2011, 10:52:28 am »
Holy Jebus, SEGA put it on the bezel?!? I didn't even think of checking mine. Mine is cracked so I just dropped it into the parts box and its been there since day one.
I'll have to check it first thing today.
Mikonos
  • Last login:July 15, 2013, 03:27:49 pm
    • Zona Arcade
« Reply #5 on: June 28, 2011, 05:04:01 pm »
I made a tutorial about this topic in  "Zona Arcade. Construye, Restaura y Decora tu Máquina Arcade y Pinball": :) :) :)
http://zonaarcade.forumcommunity.net/?t=44108316
Into image ""SEGA Original Seal" for Bezel". By Mikonos.
Repro "SEGA Original Seal" for Bezel. By Mikonos.
Regards
SavannahLion
« Reply #6 on: June 30, 2011, 03:19:44 am »
Whoah, nice to know I'm not the only one. Problem is... I actually don't have the sticker on the bezel.
I was going to return and respond to my last post but didn't see much point in it. I dug the bezel out of where I stored the cab for the last couple of years. Almost forgot I even had it. To my disappointment, I don't have the sticker. I don't even have a hint of one.
I think I know why. I don't think I have the original bezel. The original has molded ridges and reliefs (which can be seen in the manual and in some online photos). Mine is smooth and plain, looks alot like a generic shroud. Hell, I'm not even sure if the bezel I have even came with the Hang-On now that I think about it. Might've been in the parts box I got with it. I probably just assumed it belonged to the cab.
My point is, my only reference to that sticker is in the manual, and as you can see, looks like crap.  :'(
Are you willing to share your working file Mikonos, or at least the original reference photo?
As for the tutorial, I do some questions.
What is, "tienda de impresión, rotulación e incluso a alguna ferretería"? I fed it into Babel but it doesn't make any sense to me.
Also ,"iridiscente o irisreflectante"? Am I to understand the first is of the type you used in the tutorial but the later is mirror-like sans pattern?
Mikonos
    • Zona Arcade
« Reply #7 on: July 23, 2011, 12:38:04 pm »
In the "Hang-On" manual you have enough information for to do a repro.
Print stores, reprography stores, doityourself shop or hardware shop.
Yes, the sticker reflects light like rainbow.
Regards
« Last Edit: July 23, 2011, 06:22:47 pm by Mikonos »
zorg
« Reply #8 on: July 23, 2011, 01:10:12 pm »
is the sega seal file availble ?
I'm on the planning stage
SavannahLion
« Reply #9 on: July 23, 2011, 02:32:24 pm »
Um...
Moving along....
Based on a number of samples located (not by me), the Sega seal actually varies from game to game. I've been meaning to analyze the seals to find out the correlation. At a minimum, seals are different between conversions and original cabs. Variations also include color schemes, whether Kanji/Kana is used and other minor details.
In a nut shell, what game are you looking for?
synonym9
  • Last login:May 04, 2015, 09:44:32 pm
« Reply #10 on: November 06, 2013, 04:51:38 pm »
Could I order such a decal.....?
SavannahLion
« Reply #11 on: November 07, 2013, 05:58:03 pm »
IIRC I believe he was offering them for about 4 euros. Or I could've mistranslated what was said. I seem to remember Babel or Google wasn't too happy with the language there.
Not sure why I never asked about buying two or three. I think because every SEGA cab had a different sticker design and the one he has there was for Shinobi. Regardless, try emailing him, I havn't seen Mikonos in a whe so he might not still be around.
Let me know how it goes.
  • Last login:Today at 05:02:13 am
« Reply #12 on: November 07, 2013, 08:32:53 pm »
I havn't seen Mikonos in a while so he might not still be around.
Caveat Emptor.
And Mikonos (by mikonos) has just been banned from dragonslairfans.com, after they tore him a new one... :applaud:
And now banned from here...
There are more details and a link to the Dragon's Lair forum thread in the thread these quotes were taken from.
SavannahLion
« Reply #13 on: November 07, 2013, 10:20:12 pm »
Wow... that got my attention.
I remember the first posts with his "gallery" but lost interest in it pretty quickly. I didn't even bother following the thread after that so I never saw any of the subsequent posts.
That totally explains his response to my posts here.
The ---smurf--- had no interest in releasing the digital files. Probably would've asked me for my files and kept them for himself.
Oh well, pooh on him should he ever try to return.
« Last Edit: November 07, 2013, 10:36:17 pm by SavannahLion »
SavannahLion
« Reply #14 on: November 07, 2013, 11:14:13 pm »
Trying to find out more and found this:
I only speak government, anyone understand what he's saying? Is that Mr. Mikonos?
« Reply #15 on: November 08, 2013, 01:53:49 am »
Pretty sure that's him talking about cleaning/maintenance on classic cabs, advancing technology, console emulators/MAME, and the place that videogames have in culture.
Apologies if I missed key points -- translating it was like getting a drink from a fire hose.   :lol
« Reply #16 on: November 08, 2013, 02:19:20 am »
Found a version of the sega stickers here.
aioros
  • Last login:August 19, 2014, 07:40:45 am
  • Love designing arcade artworks
« Reply #17 on: November 08, 2013, 05:09:46 am »
...and here too  ;)
I made them starting from the Shinobi bezel available in MrDo's website and the "Turbo" bezel. The first one corresponds to games like Shinobi or Wonderboy (it looks much better than the other one).
Help me!!! I see vectors everywhere!!
SavannahLion
« Reply #18 on: November 08, 2013, 10:05:51 am »
Where were you two say... two years ago?!?  :cheers:
IIRC  the one with the stylized edging is the closest style. I'll have to pull my restoration notes..
synonym9
« Reply #19 on: November 10, 2013, 04:43:55 pm »
From what I understood....this is what you are looking for.
I need to wait for my tools to continue the dismantleing of the cab. I then will remove the plexi and try to make a quality image....scanning could be a problem as it is on bent surface....
http://s1298.photobucket.com/user/synonym999/media/Hang-On%20restoration/SegaSeal_zps37040242.jpg.html
aioros
« Reply #20 on: November 11, 2013, 10:47:51 am »
Thanks for the image, synonym9.
Taking it as a reference, I've modified the previous version to reproduce this one. Not perfect but pretty good :)
PDF files:
Hang On Version -> http://www.mediafire.com/download/39t1zq7qpa4jqq7/Sello_de_Licencia_HANG_on.pdf
Blank Version -> http://www.mediafire.com/download/11l7s0uuf610n0b/Sello_de_Licencia_V3_para_cubrir.pdf
« Last Edit: November 11, 2013, 12:27:51 pm by aioros »
synonym9
« Reply #21 on: November 13, 2013, 03:15:32 pm »
I have the bezel disassembled now, if you still can need it i make a better image of it now.
How to use your work? I need such a reflecting sticker and then your decal is to put on that reflective sticker?
If so, where to buy such stickers?
« Reply #22 on: November 13, 2013, 04:36:57 pm »
I'm looking for some kind of laser-printable holographic paper as well to make these.
« Reply #23 on: November 13, 2013, 07:55:10 pm »
Found several possible leads using keywords like reflective, iridescent, prism, prismatic, etc.
Holographic tape 1
Holographic tape 2
Holographic tape 3
Not sure where you can get this locally or in small quantities, but this reflective sheeting looks lilke a promising lead.
5.Printable, you can print on surface directly. Screen printing,Digital printing or other printing methods are all possible;
synonym9
« Reply #24 on: November 14, 2013, 06:21:53 pm »
Holographic tape 1
Holographic tape 2
VERY VERY NICE.....
I also have a picture of the screen glass sticker. If you guys are interested I go for get it high res-scanned.
http://s1298.photobucket.com/user/synonym999/media/Hang-On%20restoration/20131115_000641_zps5acbce10.jpg.html
Tell me if there is a use for it.
Holographic tape 3
synonym9
« Reply #25 on: November 15, 2013, 05:27:58 am »
Maybe somebody is also interested in that:
If so I will provide a high-res scan as I want to reproduce it for perservation anyways.
Next week I get my Hang-On NOS-gauges (2 pieces) I also will scan them so if any one wants to restore his Sega cabinet he can download it and apply it on a plexi-plate and will have perfect gauges!
« Reply #26 on: November 15, 2013, 06:45:13 am »
VERY VERY NICE.....
Thank you.  :cheers:
I'm sure that the art restoration gurus around here would love to get any high quality scans/photos that you can provide, especially if you include a ruler for scale so they can make everything the correct size.    :applaud:
AFAIK the only repro'd Hang-On art is the side swoop (several places), the Sega seal stickers, and the marquee. (Joymonkey's paysite)
synonym9
« Reply #27 on: November 15, 2013, 07:29:10 am »
Thanks. I could not manage it setup an account.....but sent a mail to the guy.
« Reply #28 on: November 15, 2013, 08:39:54 am »
If you want to buy a Hang-On marquee, Game On Grafix and Emdkay carry them.
If you're looking for sites to host your files, the Arcade Art Library and this site are both great choices that allow free access for others.   ;D
« Reply #29 on: November 15, 2013, 02:05:25 pm »
I read that EMDKAY is closed right now.
« Reply #30 on: November 15, 2013, 03:49:42 pm »
Good catch.  :cheers:
Missed the announcement at the bottom of the main page.   :badmood:
