Author Topic: Layout : snap instead of marquees - resizing  (Read 2358 times)
dosmame
  • Last login:November 22, 2012, 09:50:13 am
    • DOS MAME
« on: June 09, 2011, 10:06:02 am »
Hi, I want to use snapshots in the game list selection, like you can with marquees.
I can see the option in the layout editor, under APPEARANCE/IMAGES & DISPLAY/SNAP and it works when I select SNAP.....but, I can't seem to get the snap size correct. If I select resize to fit, the snap becomes marquee sized, i.e. wide and short. If I don't select resize to fit, the snaps are the correct aspect ratio, but only tiny due to the height of the marquees.
I've also changed some of the game list/layout options without success.
So, can I modify the snap image size?
TIA
DM :-D
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Layout : snap instead of marquees - resizing
« Reply #1 on: June 10, 2011, 10:03:29 pm »
TIA
DM :-D
Sounds like you want to enable transparency in the editor and have it larger
