Author Topic: Mortal Kombat 2 Dynamo Conversion refresh : Kampcool  (Read 4671 times)
kampcool
  • Last login:September 22, 2011, 04:43:59 am
« on: June 04, 2011, 03:10:21 am »
I have already ordered a new Marquee, and some competition joysticks.  I have really cleaned up the picture since I photographed it, but I still get interupted with a squashed presentation, and lines.......   The display is a Wells Gardner 25k7184 (K7000).
Also, the machine restarts intermittenly, as if someone turned it off and back on.  The power supply is a u-san electron ltd Peter Chou 11-150v-3
I should probably address the power supply 1st, as this (but not probable) COULD be causing some display issues.  Start at the source, right?
Any thoughts here, much appreciated.
« Last Edit: June 04, 2011, 05:32:35 am by kampcool »
kalars123
  • Last login:August 09, 2019, 12:31:51 pm
Re: Mortal Kombat 2 Dynamo Conversion refresh : Kampcool
« Reply #1 on: June 04, 2011, 04:08:45 am »
It wouldn't surprise if your PS was causing that, are they rolling lines or static?, rolling lines like are normally caused by a grounding issue, or interference. IE like back in the day when your TV would go crazy when mom vacuumed
« Last Edit: June 04, 2011, 09:55:06 am by kalars123 »
kampcool
« Reply #2 on: June 04, 2011, 05:30:01 am »
Roger That, but these are static lines, always present, and then after unit heats up, (about 3 fights in) screen shrinks, and lines become predominate in the middle.  I just ordered a cap kit for a wells gardner k7000, we will see if that does the trick.     I cannot immediately find a link to the power supply.      Here are the numbers I have found:  U-San Electron Ltd. Peter Chou. Model USP 11-150V-3   Sn4101795 (which is also the patent#), Before I power up my Wells Gardner 25k7184, I really would like a replaced Power Supply.     HELP!?
kalars123
« Reply #3 on: June 04, 2011, 10:01:03 am »
If your restoring it to a working MK2 cabinet then you have 2 option's you can follow this guys stuff to use a PC power supply "350w would prolly be good"
http://www.habosarcade.com/MortalKombatMulti%20JammaCab.htm#PC%20Power%20Supplies
OR
http://www.happ.com/powersupplies/80000300.htm
is what I use in my UMK3 cabinet
"edit"
also check what your -5v is putting out MK boards are VERY VERY finicky about -5 if it's not enough they will do all kinds of weird things.
kampcool
« Reply #4 on: June 06, 2011, 05:50:40 pm »
there is a pot dial on my powersupply, i adjusted it acordingly, and have no power shutdowns anymore.
kampcool
« Reply #5 on: June 07, 2011, 06:42:07 am »
I "SEE" that so clearly now.  My P/S is fine, it has a POT adjust, that I needed to tweak to get the -5.
kampcool
« Reply #6 on: June 09, 2011, 05:35:17 am »
Got my new Comp Happ Joysticks, and a capkit today............More pictures incoming this weekend, as I take out that Wells Gardner 25k7184, and talk about those new HAPP competition sticks, as they are installed.
kampcool
« Reply #7 on: June 09, 2011, 11:40:20 pm »
hey guys putting a cap kit in this weekend on this Wells Gardner 25k7184 (K7000).    Outside of the flyback, are there any other discharge concerns I should be aware of?   This is my 1st wellsgardner, so any tips would be appreciated.
kampcool
« Reply #8 on: June 11, 2011, 06:26:56 am »
A couple of odd finds upon discharge and removal of my 25k7184 wellsgardner from this MK2 conversion.  Now please forgive me if I am wrong about identifying stuff, as I am green as the Panama jungle here, but I promise, I pickup quick.  Everything was normal looking, until I went to unplug the yoke connector(pretty sure thats what its called) off of the chasis board.
kampcool
« Reply #9 on: June 11, 2011, 06:31:20 am »
It was very cluttered in there, when I realized there was a big piece of rubber debris, wedged right to the bottom.
I have no idea what it is, or its importance, but I have set it off to the side, as I know it doesnt belong.
kampcool
« Reply #10 on: June 11, 2011, 06:34:47 am »
The second ODD thing I noticed was a vertically mounted sister board (THAT WAS SUPER LOOSE/FLAPPING IN THE WIND).
Whats this one called?
kampcool
« Reply #11 on: June 11, 2011, 06:41:27 am »
Gee I wonder why I could just "Fonzerelly" gently to the right of my marquee, and get rid off THIS:
I bet if I just did a reflow here, she MIGHT be fine:
Half of these joints are visibly loose.
kampcool
« Reply #12 on: June 11, 2011, 07:21:06 am »
But......what the hell, right.  Ive come this far.  I have a capkit, a new gun holder(I DID learn during the G07), and some solder.   Ive read ALOT of the Wells Gardner horrors, and I have to say, I am apprehensive.  I want to learn, and I do NOT want to dissapoint (teenagers are waiting).
My biggest fear is discovering someone elses failed repair.   This sure doesnt look "stock",    OMG!   IS THIS COMMON?
« Last Edit: June 11, 2011, 07:30:35 am by kampcool »
kampcool
« Reply #13 on: June 17, 2011, 06:28:42 am »
Ill just assume this is what a stock wells gardner 25k7943 is supposed to look like.  Im at the half way point in the cap install, and I do miss working on the G07 already.  They must have mass produced these bad boys at a furious pace,........
kampcool
« Reply #14 on: June 17, 2011, 10:24:31 am »
Yeah, I definately liked the capjob on the G07 better, it was labeled better, I guess.   However the Wells Gardner didnt have as many "Tight, small solder points"  I couldnt believe the sloppy factory solders on this 25k7184, tho..   The Canadians did A much more quality job on the G07.
This was intimidating, but wound up being easier than I thought (read too many horror stories, I guess).
kalars123
« Reply #15 on: June 17, 2011, 01:31:23 pm »
glad to see you got it working, sorry i couldn't be much more help but i know little to nothing about crt repair
