Author Topic: IPAC needs to reprogrammed after each reboot  (Read 1446 times)
DeeGor
  • Last login:July 31, 2024, 11:13:10 pm
« on: May 30, 2011, 12:00:42 pm »
I'm having an odd issue where my IPAC forgets the custom keys I have programmed on the IPAC after a reboot.  This IPAC has worked fine for years, and the only difference is I recently upgraded to Windows 7 on my cabinet.
Has anyone else run into this issue, and how were you able to solve it?
My virtual pinball cabinet: LEGO Batpin
DeeGor
Re: IPAC needs to reprogrammed after each reboot
« Reply #1 on: May 30, 2011, 12:26:05 pm »
I did some more testing and it looks like the programming survives a reboot.  I thought it was a reboot, because every time I turned the cabinet on in the morning, the keys were back to their default settings.
BobA
  • What Me Worry?
« Reply #2 on: May 30, 2011, 04:33:47 pm »
Did you buy the VE edition.  It needs to be reprogrammed after a power down of the PC if you use a custom code set.  The regular MAME codes are held.
Ipac VE
DeeGor
« Reply #3 on: May 30, 2011, 07:12:09 pm »
No, It's not the VE edition.  It was working fine for a few years, and now that I've upgraded, I'm having these problems.
BobA
  • What Me Worry?
« Reply #4 on: May 30, 2011, 08:44:13 pm »
Check with Andy at Ultimarc if you upgraded.  He may be able to help.
