Author Topic: Hacked Dreamcast Controller Problem/Question  (Read 1649 times)
Larrabee
  • Last login:June 01, 2011, 07:01:24 pm
« on: May 28, 2011, 12:30:53 pm »
After hooking up my hacked DC controllers (thank you fast ebay shipping!). I have having a different problem on each controller. I am using some the mad catz ones like this one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&rt=nc&nma=true&item=270751035166&si=3iOUzYHfJTW0QUZ5tSSXV3PgkVU%253D&viewitem=
Controller 1: All of the buttons/directions don't work at bootup. If I up plug and then plug the controller back in, the buttons and sticks work perfectly.
Controller 2: This seems to be a bigger issue, works fine at startup, all buttons/directions work great. Then every 10 seconds or so I will get a prompt saying that a memory card had just been plugged in or the controller was removed. Then without doing anything it will work again. Seriously, if I just let it sit there it will keep going back and forth from working to not ever 10-15 seconds.
I rewired the whole CP, and double checked everything. Any ideas what could be going on?
Thanks.
Shun
  • Last login:December 09, 2025, 05:14:48 pm
Re: Hacked Dreamcast Controller Problem/Question
« Reply #1 on: September 17, 2011, 10:19:24 am »
I was just about to create a new thread about the very issue you are having with controller 2.
The problem that I having with the Dreamcast is as follows:
When I play games that have a maximum of 2 players and two players are playing the game (Soul Calibur and Marvel Vs Capcom 2 for example) it plays great. However when I play games that can have a maximum of 4 players and 2 players are playing  (Virtua Tennis 2, Virtua Striker 2 although strangely Power Stone 1 causes the same problem) the game is paused by player 2 at random. I thought it was player two's start button sticking but I disconnected it and it still happened.
My controls are wired up as follows:
The minipac is connected via PS/2 to my KVM switch. One side of the kvm goes to the PC while the other side goes to the Dreamcast. The PS/2 cable from the KVM goes in to this adapter that I bought off of Ultimarc
http://www.ultimarc.com/dreamcast.html
The adaptor then plugs in to ports 1 and 2 of the dreamcast.
I thought it might be an issue with the dreamcast so I plugged the adaptor into another dreamcast but I still had the same issue. When I plugged the adaptor into ports 1 and 3 and played my test game Virtua Tennis 2 the problem went away!!!! So I don't have any idea what is causing the problem.
I suppose I could try and bypass the KVM but it will be a pain in the arse taking out some of the wires. Although I can't see how it can be the KVM when there is no problem when plugged in to port 1 and 3. If anybody has any ideas they would be very welcome as this is stopping a lot of my Dreamcast games being played in two player mode.
Here is a video of Power Stone running on my cab:
Before the game pauses a memory card error is displayed:
"No memory card found! Make sure that your memory card and controllers are connected properly."
Virtua Tennis 2 (picture below) does the same thing however it doesn't display a memory card error.
Complete: Pac-Man Cabaret scratch build:
Project thread
Work in progress:
Two Phase Bartop With Flush Mounted Dreamcast. 75% Complete
