Author Topic: New Q? Z26 version modified for arcade cabs  (Read 1363 times)
Hoagie_one
  • Um....whats a cabinet
« on: August 29, 2003, 08:48:04 pm »
I use Mamewah with it and i got it running but it plays in the tiny little window on the screen.  How to I set it to play full screen, or at least in a bigger screen.
Ive never used z26 so im not sure how it works.
Thanks guys, you really are helpin me out a bunch lately.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:New Q? Z26 version modified for arcade cabs
« Reply #1 on: August 29, 2003, 09:02:46 pm »
check stuzza's site, he has emus made for arcades...
any1 who ever needs an arcadified emu should look there, hes got quite a few
It's all about the Pentiums
Hoagie_one
« Reply #2 on: August 29, 2003, 09:10:38 pm »
thats where i got it from and it runs great.  Just want to know how to set it to run full screen or in a bigger box if not full screen
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #3 on: August 29, 2003, 10:20:18 pm »
There is a command line switch for Z26 which allows you to specify full screen mode at varying resolutions and refresh rates.
I use the "-v1" command line switch which runs it at Full screen, but I can't off hand remember what resolution etc.. the 1 specifies??
In Mamewah you can specify this command switch in the "Default Options" section of the config file.
ie. default options = -v1
That way it will load each rom full screen.
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #4 on: August 29, 2003, 11:43:11 pm »
Are the Atari pixels 1-inch squares at that resolution ??   ;)
Hoagie_one
« Reply #5 on: August 29, 2003, 11:52:51 pm »
thx, worked perfectly
stuzza
    • ScreenshotArchive
« Reply #6 on: August 30, 2003, 01:53:26 am »
LOL, yep there pretty big squares  ;D  Although since they are just squares anyway the screen looks just the same but bigger! LOL
