Author Topic: Is this all I need?- J-Pac and Arcade 3000?  (Read 2886 times)
rmusick
  • Last login:November 12, 2017, 09:15:41 pm
« on: May 13, 2011, 04:11:15 pm »
Hey question.  I just recently came into a Mortal Kombat cabinet.  One of the boards is bad on it(will research what is broke on it later.)  What I want to know is this,  If I get a PC with Arcade VGA 3000 and a J-Pac,  Could I plug in the Jama connector to the j-Pac and the arcade 3000 as well, and run with it, or do I Have to do some hacks? I really don't want to "Destroy" this just to be able to play it for now.
thanks.   :-\
Goonie
  • Newbie
  • Last login:May 13, 2011, 04:56:49 pm
Re: Is this all I need?- J-Pac and Arcade 3000?
« Reply #1 on: May 13, 2011, 04:53:50 pm »
Hey.  From what I know, yes, that's all you need.  I have an MK2 cabinet with a Playstation 2 hooked up right to the JPac.  The Jamma harnes flows through to everything properly.
krick
  • Gotta have blue hair.
« Reply #2 on: May 13, 2011, 05:38:44 pm »
The vast majority of arcade games used a low resolution (15KHz) arcade monitor.
I'm not sure, but I thought that Mortal Kombat was one of the games that used a medium resolution (25KHz) arcade monitor.
If that's the case, you might want to see if you can change a jumper on the monitor to put it in low res (15KHz) mode.  As far as I know, most medium res monitors have this jumper.
More info...  http://www.ultimarc.com/monfaq.html
Non 15Khz Arcade Monitors
There are three other types of arcade monitors besides 15Khz fixed frequency:
25 Khz monitors. If you have a choice, don't go for one of these. They cannot display any of the early games at native resolutions as the scan rate is too high. Only a few games used these monitors and only these few games can be displayed 100% accurately on them. Advanced MAME will be needed for these monitors.
VGA arcade monitors. Avoid these if you can. These give all the disadvantages of using a PC VGA monitor and none of the advantages. Only later games will be able to be displayed at native resolution. Almost all games will need hardware stretching.
Full-Range 15Khz - 31Khz multi-scan arcade monitors. For example the D9200. Very Nice! Expensive but can display ANY game at it's native resolution. These can be used with an ArcadeVGA card to display 15Khz and 31Khz resolutions, using a special installable utility for the card. Bear in mind that if you have one of these monitors, using it with an ordinary VGA card will only run it at 31Khz (unless you use Advanced MAME) so you will not be taking advantage of it's full potential and ability to display native arcade resolutions as well as Windows VGA resolutions.
« Last Edit: May 13, 2011, 05:40:34 pm by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
rmusick
« Reply #3 on: May 13, 2011, 09:06:45 pm »
well i guess im screwed  :angry:  I just looked and there is no switch.   :banghead:  it is a Wells Gardner 25K7197 monitor.  even if it is 25hz, couldnt I still use it. I mean it would still be better than a Tv or a VGA monitor right???
rmusick
« Reply #4 on: May 13, 2011, 09:24:53 pm »
I saw this link on here where sman6452 was doing the same thing I am trying to do, but the thread ends in 2008 so I don't now what became of it.
http://forum.arcadecontrols.com/index.php?topic=76955.0
anyway enough of this for the night got to watch the final episode of Smallville  ;D
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: May 14, 2011, 10:23:49 am »
Nope Mortal Kombat definitely used a 15Khz monitor
rmusick
« Reply #6 on: May 14, 2011, 10:48:10 am »
;D ;D ;D ;D ;D ;D ;D ;D :cheers: :applaud: :applaud: :applaud:
Sorry just a little excited there !
rmusick
« Reply #7 on: May 14, 2011, 12:47:25 pm »
oops I think I left this out Its a MK2 Cab not just a MK cabinet.. Hope that doesnt make a difference
AndyWarne
    • Ultimarc
« Reply #8 on: May 14, 2011, 04:11:19 pm »
Still 15Khz. You can check on www.klov.com
Andy
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #9 on: May 14, 2011, 07:19:20 pm »
Just curious if the boards are bad are you sure the monitor even works?
rmusick
« Reply #10 on: May 15, 2011, 07:58:21 am »
Its the sound board that doesn't work.  Video works fine has a GREAT picture on it.
tommyinajar
« Reply #11 on: May 15, 2011, 02:17:51 pm »
If you check the caps and the wiring and maybe you'll have a GREAT WORKING Mortal Kombat ][ cab :)
http://forum.arcadeotaku.com/viewtopic.php?f=26&t=11592
rmusick
« Reply #12 on: May 15, 2011, 02:22:06 pm »
If you check the caps and the wiring and maybe you'll have a GREAT WORKING Mortal Kombat ][ cab Smiley
The Roms are missing from the sound card, Just have to look up which ones I need.
rmusick
« Reply #13 on: May 15, 2011, 02:24:06 pm »
not sure if this matters or not.  I did a test today.  I have a 60n1 card I plugged it into the JAMMA connector and fired it up.. The monitor went crazy..(Kinda the way it does when you put a resolution on a PC monitor and its not designed to do IE, Run 1024x768 on a 640x480 monitor)  Anyway I checked the card it was set for 15khz
AndyWarne
    • Ultimarc
« Reply #14 on: May 16, 2011, 09:56:06 am »
Although MK used 15Khz monitors the video settings were rather weird. You may need to adjust the V Hold control and possibly the other controls when moving to a more standard resolution.
rmusick
« Reply #15 on: May 16, 2011, 07:34:43 pm »
That got it.. was able to stop the "Scroll" and stabilize it although now my monitor has the shakes  :banghead:  However from what I have read on here its a bad solder joint and WG is notorious for having those.  My cousin works on TVs he said he could have it fixed in about 15 minutes.. now the pain is pulling the monitor out.
