Author Topic: Kodak 3000 touchscreen software???  (Read 3728 times)
uolarethian
  • Last login:March 20, 2025, 04:28:09 pm
  • Should I eat'em or what?
« on: May 12, 2011, 02:50:32 pm »
I picked up a Kodak 3000 touchscreen off Ebay in hopes of making a jukebox with it.  I guess I should have looked for the touchscreen software first because I can't seam to find any for it.  Has anyone used one of these before, there the monitors that were in the Kodak kiosk's from what I am told.
Thank for any help
Encryptor
  • Trade Count: (+34)
Re: Kodak 3000 touchscreen software???
« Reply #1 on: May 12, 2011, 07:21:52 pm »
Are there any other markings? Labels? Model #?
Hoopz
  • Intellivision Rocks!
« Reply #2 on: May 12, 2011, 08:24:24 pm »
Can you install Belarc Advisor to get the motherboard info?
uolarethian
« Reply #3 on: May 12, 2011, 10:42:41 pm »
There are no other markings other then the serial number and service code, (2917)  It is labeled as "Kodak digital monitor 3000"
as for the Belarc Advisor I will look into seeing if I can get the motherboard info that way if it will help.
  • Last login:February 21, 2026, 05:58:33 pm
« Reply #4 on: May 13, 2011, 01:11:38 am »
If you can't find drivers you are going to need to find spec-sheets on the monitor at least... then maybe someone can program mouse emulation for you.
Is the touch screen connector usb or serial?
  • Last login:February 22, 2026, 09:34:29 am
« Reply #5 on: May 13, 2011, 09:25:32 am »
Give ELO drivers a try (XPU4.8.7b)
http://www.elotouch.com/Support/Downloads/dnld.asp
I've seen off brand touchscreens for sale on ebay that claim the ELO drivers work with them.
If it doesn't work, remember to uninstall the elo software & driver before trying a different one.
Hoopz
« Reply #6 on: May 13, 2011, 09:37:10 am »
With Belarc, you'll get more than the mobo info.  You'll also see all the drivers that are installed, hardware etc.  It'll help you to know what you have so you can search for the correct drivers.
uolarethian
« Reply #7 on: May 13, 2011, 02:41:37 pm »
It is connected thru the serial port. I am trying the ELO software and installing the Belarc too. I will keep you updated.  Thanks everyone.
uolarethian
« Reply #8 on: May 13, 2011, 02:46:22 pm »
 :timebomb: BOOM!!!!   The ELO software worked like a charm.  Thank you again for all the help.
« Reply #9 on: May 13, 2011, 02:58:46 pm »
Glad it worked.  :cheers:
In case you didn't notice it, there is an ELO icon under Control Panel in windows that lets you access calibration/settings, etc.
