Author Topic: Mala 1.74 crash  (Read 2934 times)
twsh
  • Last login:May 13, 2011, 08:01:25 am
Mala 1.74 crash
« on: May 10, 2011, 03:20:54 pm »
Hi
  I'm using mala 1.74 but when I scroll down the rom list it crashes randomly. This is a fragment of ther error log:
2011/05/08  20:16:45.35   Info: ##########################################################################
2011/05/08  20:16:45.35   Info: Starting MaLa 1.7.4.0
2011/05/08  20:16:45.35   Info: LoggingLevel =  1
2011/05/08  20:16:45.35   Info: Starting usb LED/LCD device detection ...
2011/05/08  20:16:45.92   Info: Hardware: *** HidCtlDeviceChange ***
2011/05/08  20:16:45.92   Info: Hardware1: Creating object
2011/05/08  20:16:45.92   Info: Number Of Connected Hardware: 0
2011/05/08  20:16:45.92   Info: Finished usb LED/LCD device detection ...
2011/05/08  20:16:45.92   Info: Showing splash
2011/05/08  20:16:45.93   Info: Check plugin directory: C:\Users\twsh\Desktop\MaLa174\plugins
2011/05/08  20:16:45.94   Info: Collecting event plugins (*.mplugin) in C:\Users\twsh\Desktop\MaLa174\plugins\
2011/05/08  20:16:45.94   Info: Check backup directory: C:\Users\twsh\Desktop\MaLa174\backups
2011/05/08  20:16:45.94   Info: Check to see if hook dll is required
2011/05/08  20:16:45.94   Info: Win98/ME Hook dll not loaded because OS is: Win7
2011/05/08  20:16:45.94   Info: Computer name: TROJANWARRIOR
2011/05/08  20:16:46.03   Info: Loading config params from ini file
2011/05/08  20:16:46.08   Info: Setting params from ini file
2011/05/08  20:16:46.08   Info: Creating and loading mame cl conditions: C:\Users\twsh\Desktop\MaLa174\mame.clc
2011/05/08  20:16:46.08   Info: Creating and loading mame info pages: C:\Users\twsh\Desktop\MaLa174\mame.mli
2011/05/08  20:16:46.09   Info: Creating and loading other emu info pages: C:\Users\twsh\Desktop\MaLa174\otheremu.mli
2011/05/08  20:16:46.09   Info: Creating and loading filter sets: C:\Users\twsh\Desktop\MaLa174\mala.mlf
2011/05/08  20:16:46.09   Info: Creating and loading other Emulators: C:\Users\twsh\Desktop\MaLa174\mala.mle
2011/05/08  20:16:46.09   Info: Collecting layout files (*.mll) in C:\Users\twsh\Desktop\MaLa174\
2011/05/08  20:16:46.09   Info: Creating and loading mala tree
2011/05/08  20:16:46.09   Info: Collecting game list files: (ml0) in C:\Users\twsh\Desktop\MaLa174\
2011/05/08  20:16:46.09   Info: Creating and loading bios
2011/05/08  20:16:46.09   Info: LoadBiosList
2011/05/08  20:16:46.10   Info: Muzac: Creating audio object
2011/05/08  20:16:46.10   Info: Muzac: Loading Playlist into Memory from FILE: C:\Users\twsh\Desktop\MaLa174\mala.pls
2011/05/08  20:16:46.10   Info: LoadPlaylist: Playlist is empty
2011/05/08  20:16:46.10   Info: Muzac: Set in Sequential
2011/05/08  20:16:46.10   Info: Muzac: Set in No Loop
2011/05/08  20:16:46.10   Info: Hardware: Loading mala lcd screens
2011/05/08  20:16:46.10   Info: Hardware: Creating and loading mame lcd screens
2011/05/08  20:16:46.10   Info: Hardware: Creating and loading jukebox lcd screens
2011/05/08  20:16:46.11   Info: Creating and loading led config and attroct mode list
2011/05/08  20:16:46.11   Info: Collecting attract mode files (*.mlc) in C:\Users\twsh\Desktop\MaLa174\
2011/05/08  20:16:48.43   Info: Hiding splash
2011/05/08  20:16:48.43   Info: SetLayout: Layout Name= standard
2011/05/08  20:16:48.44   Info: SetLayout: Loading layout: C:\Users\twsh\Desktop\MaLa174\standard.mll
2011/05/08  20:16:48.80   Info: LoadPicture: MaLa Tree Attempting to load \MaLa Menu_Mame
2011/05/08  20:16:48.80   Info: Show Main Form
2011/05/08  20:16:48.82   Info: FormActivate:
2011/05/08  20:16:48.82   Info: Video: Start initial delay
2011/05/08  20:16:48.90   Info: LoadPicture: MaLa Tree Attempting to load \Mame
2011/05/08  20:23:51.13   Info: LoadPicture: MaLa Tree Attempting to load \MaLa Menu_Megadrive
2011/05/08  20:23:51.34   Info: LoadPicture: MaLa Tree Attempting to load \Megadrive
2011/05/08  20:23:51.62   Info: LoadPicture: MaLa Tree Attempting to load \MaLa Menu_Mame
2011/05/08  20:23:51.84   Info: LoadPicture: MaLa Tree Attempting to load \Mame
2011/05/08  20:23:52.61   Info: LoadPicture: MaLa Tree Attempting to load \MaLa Menu_Megadrive
2011/05/08  20:23:52.71   Info: LoadPicture: MaLa Tree Attempting to load \Megadrive
2011/05/08  20:23:53.19   Info: LoadPicture: MaLa Tree Attempting to load \MaLa Menu_Mame
2011/05/08  20:23:53.42   Info: LoadPicture: MaLa Tree Attempting to load \Mame
2011/05/08  20:23:57.42   Info: SetLayout: Layout Name=
2011/05/08  20:23:57.45   Info: SetLayout: Loading layout: C:\Users\twsh\Desktop\MaLa174\standard.mll.mll
2011/05/08  20:23:57.54   Info: Game List: Hiding Blend Window to reveal new list
2011/05/08  20:23:57.54   Info: FormActivate:
2011/05/08  20:24:00.85   Info: SetLayout: Layout Name= standard
2011/05/08  20:24:00.87   Info: SetLayout: Loading layout: C:\Users\twsh\Desktop\MaLa174\standard.mll
2011/05/08  20:24:01.18   Info: LoadGameList : Loading C:\Users\twsh\Desktop\MaLa174\All Games.mlg
2011/05/08  20:24:01.25   Info: Current Memory used: 32.992 K
2011/05/08  20:24:01.36   Info: Game List: Hiding Blend Window to reveal new list
2011/05/08  20:24:01.36   Info: FormActivate:
2011/05/08  20:24:11.34   Error: Exception Message: Scan line index out of range, Object Function: LoadPicture, Exception Class: EInvalidGraphicOperation, Object Class: TfrmMain
2011/05/08  20:24:14.54   Info: Showing taskbar
2011/05/08  20:24:14.55   Error: AppException: Terminating MaLa
2011/05/08  20:24:14.56   Info: Screensaver: ScreenSaver Form Destroyed
Any suggestions??
Thanks in advance.
loadman
  • Moderator
    • MaLa
Re: Mala 1.74 crash
« Reply #1 on: May 10, 2011, 11:03:24 pm »
Looks like a bad grafic in your layout
Does it happen on the same game(s)?
If you put the log in debug mode it wil show the name of the graphic it was trying to load.
"2011/05/08  20:24:11.34   Error: Exception Message: Scan line index out of range, Object Function: LoadPicture, Exception Class: EInvalidGraphicOperation, Object Class: TfrmMain"
« Last Edit: May 10, 2011, 11:05:39 pm by loadman »
twsh
Re: Mala 1.74 crash
« Reply #2 on: May 11, 2011, 06:18:00 am »
No, it happens with any game randomly. How do I put the log in debug mode??
scream1973
  • Last login:July 25, 2014, 10:28:46 am
Re: Mala 1.74 crash
« Reply #3 on: May 11, 2011, 10:49:37 am »
I had that happen when i had bios files my game list..
Removed them and been good since.
twsh
Re: Mala 1.74 crash
« Reply #4 on: May 11, 2011, 12:27:14 pm »
Thanks scream1973 I will try this fix.
