Author Topic: Best filler for wood defects  (Read 2290 times)
mytymaus007
« on: May 09, 2011, 03:43:21 pm »
Just ripped off laminate from the side of my cab. OOps and some of the 1st layer of 3/4 plywood I would like to paint it but want to make sure i fill in all the defects, cracks etc. What the best filler to use for the least amount of $$$
EightBySix
Re: Best filler for wood defects
« Reply #1 on: May 10, 2011, 12:48:03 pm »
Sawdust, from the wood to be filled, mixed with clear drying glue. Or if you're painting it, then any sawdust/glue mix.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #2 on: June 01, 2011, 07:23:00 pm »
I use automotive bondo. It dries hard and sands easily. Really cheap too.
« Reply #3 on: June 01, 2011, 09:38:25 pm »
The best wood filler I've used is called WunderFill, you can get it at Rocklers.
It's not cheap, but it's BY FAR the best filler I've worked with.
The crap you get at Home Depot just doesn't even come close.
But that's for actual furniture work where you'll be staining the wood. If you're just wanting to patch up damaged wood that you'll be painting, Wood glue and sawdust works well, or just about any filler will do for that.
