Author Topic: Recommend best emulators that work with Mamewah.  (Read 2526 times)
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
« on: August 28, 2003, 04:25:31 pm »
The othe night I was messing around with some old roms and before I got into really customizing i was curious.
Which emulators work best with mamewah, I found that the ones i loaded into mamewah  still wanted to launch their own interface regardless. Am I doing something wrong? ???
Looking for Snes, nes, genesis, and N64. Thanks
Check out my site: http://www.said7.com
Arcade site comming soon.
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
Re:Recommend best emulators that work with Mamewah.
« Reply #1 on: August 28, 2003, 05:05:02 pm »
Here is a baseline of what works on mine w/o any GUIs showing:
MAME (command line version)
SNES = ZSNESW (arcade compile version.. find in forums here)
NES = NNNesterJ (using Howard's wrapper)
N64 = Project64 (using Howard's wrapper)
Genesis = ?? don't use myself .. think I played with GENS before, but someone else would be better to ask there.
djll
  • Last login:September 28, 2009, 04:26:13 pm
« Reply #2 on: August 28, 2003, 06:24:28 pm »
Howard's wrapper?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #3 on: August 28, 2003, 07:07:24 pm »
at stuzza's site he has emu's for genisis, n64, nes, snes and atari 2600 that are costumized for cabs and he has the mamewah instructions as well...
It's all about the Pentiums
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #4 on: August 28, 2003, 09:38:23 pm »
If you go to MameWAH's web site, and follow the links, he links to a web site with all this info.. including what settings to use in MameWAH and links to the re-compiled binaries for all these emulators that are MameWAH friendly.
GoldenBear
  • Last login:March 27, 2004, 07:27:48 pm
  • El Oso de Oro
    • Bearz Inn
« Reply #5 on: August 29, 2003, 12:10:13 am »
ZSNES (only get the custom version if you demand exit on esc, otherwise it's customizable)
VirtuaNES (Same deal as above)
As for the rest, I haven't found any good ones yet.
GoldenBear
TalkingOctopus
    • My Arcade
« Reply #6 on: August 29, 2003, 01:25:09 am »
SNES - zSNESfe
NES - VirtuaNes
Genesis - GensFE
N64 - Project 64
The FE versions of gens and zsnes exit when you press escape.
Check out this thread to make VirtuaNes exit w/ the esc key:
http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=10966;start=msg83884#msg83884
Stuzza has a Project64 esc key and the FE emulators posted here:
http://members.lycos.co.uk/stuzza12/help.htm
« Last Edit: August 29, 2003, 12:37:07 pm by TalkingOctopus »
JoeB
  • NES Fanatic
« Reply #7 on: August 29, 2003, 10:18:15 am »
Here's the link for the great info:
said7
    • www.said7.com
« Reply #8 on: September 03, 2003, 03:39:01 pm »
Thanks very helpful.  :)
