Author Topic: Let those circuits spin! We are having fun with a new product :)  (Read 2421 times)
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
This is a 6 conductor set up that will allow circuits to rotate.  It's the perfect addition to any lit stick.  These devices are usually very expensive but we made a bulk deal and should be able to sell them for 20 each.  I know not that cheap, but they have 6 conductors...hmm I guess that means something else should be coming out shortly!
  • Last login:August 17, 2025, 04:58:40 pm
Re: Let those circuits spin! We are having fun with a new product :)
« Reply #1 on: May 03, 2011, 03:47:39 am »
Wow, you really test stuff in the hardest conditions.  :applaud: "Should work for most people".  :laugh2:
NipRing
  • Last login:March 28, 2025, 10:46:34 pm
  • I love cats but i just cant eat a whole one myself
« Reply #2 on: May 03, 2011, 07:51:13 am »
I think i just had a seizure  :dizzy:, great product though!
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: May 03, 2011, 08:28:27 am »
With 6 connections you could do an RGB and a top mounted button!
Robots will kill you.
Arcade Addiction
Bender
« Reply #4 on: May 03, 2011, 09:58:38 am »
YESSSSSSSSSSS!!!!!!!! :cheers: :cheers: :cheers: :cheers:   a tiny slip ring, F-ing genius, I cant tell you how happy this makes me ;D ;D
I've kept this quite, but I actually did get the RGB/rotary/topfire/U360 working,(that's right one joystick to rule them all) but with much difficulty, the toughest part being the rotation of the wires, I went with the a 4 pole mini plug (plus I used the shaft as a the common) and it works OK, but this looks like a much more elegant and durable solution, can't wait to get my hand on some
Taking orders yet?
Must Have NOW!!!!
armi0024, Seriously PM me the second you a couple ready to ship
EDIT: just had another thought....  Oh My usb has only 5 conductors, ohhh the possibilities!!!
« Last Edit: May 03, 2011, 10:12:42 am by Bender »
« Reply #5 on: May 03, 2011, 10:23:05 am »
You could use these to make your own retractable usb cord reel which would be cheaper than this route.
whammoed
  • Last login:August 19, 2025, 10:46:15 am
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: May 03, 2011, 11:57:23 am »
Have a datasheet with dimensions?
