Author Topic: pc (Mala) to Vision Pro connections questions  (Read 1311 times)
Cartouche
  • Last login:June 25, 2011, 09:51:53 pm
« on: April 18, 2011, 08:22:33 am »
Hi gang-
I'm converting a jamma/60-in-1 to a Mame w/Mala front end and have a question or two. I'm using a Vision Pro open frame monitor, and my pc is fitted with an older version of the Ultimarc ArcadeVGA card.
Which way should I connect the two? I saw this tutorial here, that seems like the quickest/cheapest way to do it, unless there's some new product or adaptor that's surfaced since then.
http://arcadecontrols.com/arcade_pc2arcade.html
Also, is an isolation transformer necessary with the VP's?
Speakers: It would be a lot easier to keep the 2 original speakers from the Taito cab I'm using, can I just splice the wiring into any PC speaker jack and plug it right in?
Thanks for any help,
Marc
