Author Topic: I have a D9200 monitor and a 4350 Radeon Card.. Where to start?  (Read 4661 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
I'm upgrading my mame cab and I ordered in a 4350 Radeon card to try. Where is a good starting place to look for setting up 15/24/31.5 modes? (If the card works I'm keeping it, if not I guess I'll get a new arcade vga.)
Later,
dabone
bitbytebit
Re: I have a D9200 monitor and a 4350 Radeon Card.. Where to start?
« Reply #1 on: April 15, 2011, 08:02:38 am »
Later,
dabone
Should work great with Windows as long as it's not Windows 7, should work even better with my Linux live CD especially if you don't have XP64 and want 64 bit :-).  In Windows 7 you are pretty much stuck with using an ArcadeVGA3000 card there, but there's other options which are cheaper too (plus more flexible, Linux can spot on the vsync and modelines per game perfectly, at least as close as the monitor can handle).  At least with the Live CD you can boot it and try it without much trouble or installing anything, and trying out the windows builds and custom radeon drivers at http://mame.groovy.org I and Calamity have worked on might be of interest to play with and compare to see which you like better.
dabone
  • Time to work...
« Reply #2 on: April 15, 2011, 07:50:42 pm »
What I was looking for is instructions / hints / a walkthru for setup.
I'll be running XP 32bit.
I remember when I setup my current arcadevga setup, I used a utility to setup the correct res for each game automatically. I seem to remember that the 15k modes are addressed as 1 scanline extra. (320x201?) Does soft 15k need anything like this?
I'm starting from scratch, I might keep mamewah, unless something much nicer is around now.
I've got a full set for 1.41u3, but I'm trying to get the 1.42 update.
Later,
dabone
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« Reply #3 on: April 15, 2011, 08:15:07 pm »
If you're running a cab, do yourself a favor and at least try the groovymame linux live cd.  I had XP64, soft 15KHZ, and a ATI4350 and had decent success, but it really, really, really doesn't compare to the live cd.  With XP, you can dial in the resolutions, but the refresh rates can cause tears, jittering, etc.  The XP version of groovymame is very nice (better than soft15KHZ if you have Calamity's drivers), but the linux distro is way better.  With the live cd, the resolutions are spot on and the refresh rates are spot on...especially since you have a D9200.  So you absolutely get the best of both worlds.
I've got the groovymame linux setup as a hd install and could not be happier.  After a couple of evenings, I pulled out the XP hard drive and it's being used elsewhere.  I had Hyperspin as a frontend on my XP setup....but I don't miss it anymore as I customized the wahcade layout to my liking.
Groovymame linux live cd: Try it....you'll like it!   :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
dabone
  • Time to work...
« Reply #4 on: April 15, 2011, 10:57:24 pm »
Thanks I'll give it a try.
Later,
dabone
dabone
  • Time to work...
« Reply #5 on: April 20, 2011, 08:10:26 pm »
Ok, groovymame linux and me do not agree, and I still want to keep my old windows games (hotd, hamster ball, etc.).
Is there a current list of compatible cards with soft 15k?
(I tried the ati drivers from the groovymame site with my radeon 4350, and my particular card is not supported.)
The list over on the german forums is ancient.
Later,
dabone
  • Last login:Yesterday at 05:28:27 pm
« Reply #6 on: April 21, 2011, 08:19:55 am »
Later,
dabone
Yes, your radeon 4350 is supported (it was my test card actually), try version based on Catalyst 9.3.
dabone
  • Time to work...
« Reply #7 on: April 24, 2011, 03:01:20 pm »
Ok apparently my card is not supported by anything, including the drivers from the maker or ati.
MSI R4350-MD512H/D3
It comes up as a VEN_1002&DEV_68E1, which crosses to a mobility part???
"ATI Mobility Radeon HD 5000 Series   " = ati2mtag_Manhattan, PCI\VEN_1002&DEV_68E1
Just looked up the reviews over at newegg and it's labeled as a 4350, but is not. This is a card to avoid.
Later,
dabone
« Last Edit: April 24, 2011, 03:08:56 pm by dabone »
dabone
  • Time to work...
« Reply #8 on: April 26, 2011, 04:42:04 pm »
Just got in a MSI R4350-MD512H
50 cents difference, but this actually has a 4350. Drivers installed fine.
Now to figure out how to use them.
Later,
dabone
« Last Edit: April 26, 2011, 04:54:56 pm by dabone »
