Author Topic: GroovyMame for arcade monitors version 0.146u4_013f  (Read 293115 times)
ozfalcon
Re: GroovyMame for arcade monitors version 0143.013
« Reply #520 on: January 24, 2012, 05:35:09 pm »
Are you using the waitvsync option????
NOTE the Typo bug: http://mamedev.org/source/src/osd/sdl/video.c.html
When is says "-waitsync" it's referring to "-waitvsync"
Code: [Select]
SwitchRes v0.013: [mslug3] (1) horizontal (320x224@59.19)->(320x224@59.19)->(320x224@33.39)
-syncrefresh specified without -waitsync. Reverting to -nosyncrefresh
Average speed: 100.00% (10 seconds)
No errors at all and the screen continuing flickering :angry: .
Now what?
[/quote]
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #521 on: January 24, 2012, 06:14:48 pm »
The problem was an incorrect monitor_spec0 line.
I launch the games from advancemenu without passing any arguments (at least that's what I think).
Earth could be the hell of another world
Ansa89
« Reply #522 on: January 31, 2012, 08:08:23 am »
With update 7 (mame 0.144u7) groovymame patch needs a little change:
Code: [Select]
--- 0144u2_groovymame_013d.diff 2012-01-31 12:35:52.075364846 +0100
+++ 0144u7_groovymame_013d.diff 2012-01-31 13:57:31.780794671 +0100
@@ -1234,7 +1234,7 @@
 diff -Nru src/emu/switchres/switchres.c src/emu/switchres/switchres.c
 --- src/emu/switchres/switchres.c      1970-01-01 01:00:00.000000000 +0100
 +++ src/emu/switchres/switchres.c      2011-12-05 19:25:14.000000000 +0100
-@@ -0,0 +1,390 @@
+@@ -0,0 +1,391 @@
 +#include "emu.h"
 +#include "emuopts.h"
@@ -1327,7 +1327,8 @@
 +        r = ATTOSECONDS_TO_HZ(devconfig->refresh_attoseconds());
 +      gameInfo->screens = 0;
-+        for (devconfig = config.first_screen(); devconfig != NULL; devconfig = devconfig->next_screen())
++      screen_device_iterator iter(config.root_device());
++      for (devconfig = iter.first(); devconfig != NULL; devconfig = iter.next())
 +                gameInfo->screens++;
 +      if (resolution->width != 0 && resolution->height != 0) {
I don't know if it needs some other workarounds due to mame upgrade, but at least it compiles ;D .
Calamity
  • Moderator
  • Last login:Yesterday at 06:41:27 pm
  • Quote me with care
« Reply #523 on: January 31, 2012, 05:36:07 pm »
Thanks Ansa, hopefully in the next days (weeks) I find some time to update GM and try this.
Steps to create a log:
Ansa89
« Reply #524 on: February 05, 2012, 04:01:31 am »
Note that we are near to mame 0.145, so a reworked patch should be fine within the new official release.
Calamity
  • Moderator
« Reply #525 on: February 05, 2012, 04:47:01 am »
Sure, I've rewritten the soundsync patch in a way that may eventually work in Linux too. I intended to launch it together with the 0.145 version. I can't build the Linux part however  ;)
Ansa89
« Reply #526 on: February 05, 2012, 06:06:34 am »
When you release it, I will try to build and test under linux.
Calamity
  • Moderator
Re: GroovyMame for arcade monitors version 0145.013e
« Reply #527 on: February 08, 2012, 02:22:56 pm »
Version 0.145 is uploaded:
http://mario.groovy.org/GroovyMame/WindowsATIDrivers/
groovymame32_0145.013e.rar
groovymame64_0145.013e.rar
groovymame32_0145.013e_wiimote_linux.tar.bz2
0145_groovymame_013e.diff
Thanks go to:
- VeS for building the Linux binary including Wiimote support.
- Ansa89 for his patch update.
Compiling notes
Apply patches in this order:
1) hi_145.txt (http://mamestuff.lowtrucks.net/MKChamp/)
2) 0145_groovymame_013e.diff (http://mario.groovy.org/GroovyMame/WindowsATIDrivers/)
Important notes about the new groovy-013e patch
Some default options have been changed in the version. Make sure to create a fresh mame.ini file.
The 'soundsync' patch has been completely rewritten in an attempt to port its functionality to the Linux side. Now there's no 'soundsync' option anymore. The emulator core has been subtly modified in a way that allows the sound to be always synchronized with the game's speed. Thus, this patch is not OS-dependent and works in Linux too.
In order to achieve this, MAME's 'syncrefresh' option has been moved from the OS layer right into the emulator core. In our humble opinion, from a design point of view, this is where it should always have been, as the 'syncrefresh' option shouldn't belong to the layer where the final wait-for-vsync implementation is performed, but be part of the emulator's throttling mechanism.
Another important implication is that the 'throttle' option now needs to be enabled in order for 'syncrefresh' to be considered. A modification of the throttling mechanism makes it possible to have 'throttle' and 'syncrefresh' enabled and still enjoy smooth scrolling. When in the game, by pressing F10, the game can be throttled/unthrotted even with 'syncrefresh' enabled.
As usual, the 'triplebuffer' option (ony Windows) can be enabled to achieve truly asynchronous tearing-less rendering, improving performance in some situations, at the cost of scroll stuttering. Notice that 'triplebuffer' has preference over 'syncrefresh', so if both are enabled, only 'triplebuffer' will be considered.
Finally, remind that the 'waitvsync' option is managed internally by GroovyMAME, so whatever value you use will be overridden. Use syncrefresh/triplebuffer instead.
Linux notes
You'll need to manually enable the 'cleanstretch' option in mame.ini in order to get the right aspect for vertical games.
Bugs fixed
- Windows: Many crashes due to the 3-threaded rendering mechanism, when running games that switch resolutions, or using ALT+ENTER, ALT+TAB, maximizing, minimizing, etc. This should be the most stable GroovyMAME version on that regard (update: still found a crash in XP-64 build, I'm afraid)
- Windows: Crash when the -nomodeline option was used.
« Last Edit: February 10, 2012, 11:40:45 am by Calamity »
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
« Reply #528 on: February 08, 2012, 06:47:53 pm »
Sounds fantastic! Thanks! Will try tonight!  ;D
My MAME/SCART/CRT blog: SCART Hunter
Ansa89
« Reply #529 on: February 09, 2012, 03:21:17 am »
I will try it ASAP.
Paradroid
    • SCART Hunter
« Reply #530 on: February 09, 2012, 06:04:29 am »
Again, thank you. It's working great here! No problems at all with the games I tried. Smooth as always! :)
Ansa89
« Reply #531 on: February 09, 2012, 04:53:31 pm »
With groovymame 0.145 the sound is scratchy (tried with galaga, tekken 3, nba hangtime) :( .
Are there some options I can set/unset?
Calamity
  • Moderator
« Reply #532 on: February 09, 2012, 05:19:43 pm »
Did you create a fresh mame.ini?
Ansa89
« Reply #533 on: February 09, 2012, 05:31:38 pm »
Yep, but (just to be sure) I will recreate it (tomorrow, because now my mom doesn't let me play with the cab... :'( ).
Any other suggestion?
Calamity
  • Moderator
« Reply #534 on: February 09, 2012, 05:40:33 pm »
Just make sure that the throttle and syncrefresh options are enabled. Possibly try disabling waitvsync.
I wanted to test it today too but for some reason the UpdateGroovyMame command failed, I guess Linux doesn't like the name I gave to the .tar file??
Ansa89
« Reply #535 on: February 09, 2012, 06:06:11 pm »
I never used that script: to compile groovymame I download all patches and sources by hand and then use a slackbuild which build a slackware package.
If you post the script, I will give a look at this.
« Last Edit: February 10, 2012, 02:56:25 am by Ansa89 »
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #536 on: February 10, 2012, 02:23:49 am »
Hello Calamity, forgets of putting the name of the compressed file of this form Groovy ****** the first letter it is with capital letter.
Calamity
  • Moderator
« Reply #537 on: February 10, 2012, 08:14:27 am »
Thanks, I've edited the file name, figured it had to be something like that, I'll never get used to Linux's case sensitivity. I'll try it later.
Calamity
  • Moderator
« Reply #538 on: February 10, 2012, 11:43:25 am »
Finally I could try the Linux version. Everything works fine here with the right options, the sound is smooth and get's adjusted to the action when syncrefresh is used and speed doesn't reach 100% (dkong, dspirit, etc.)
Ansa89
« Reply #539 on: February 10, 2012, 12:12:12 pm »
With throttle, sycrefresh and waitvsync all enabled, the sound is a bit delayed (with Tekken 3 if I hit the opponent, I hear the hit-sound a bit after I should hear it; same with galaga).
Now I will try disabling waitvsync.
Calamity
  • Moderator
« Reply #540 on: February 10, 2012, 12:26:37 pm »
I didn't notice that exactly (tested tekken3 and galaga too among others). Please check the speed these games are running. With -syncrefresh enabled, galaga runs at 89% in my system, tekken3 can't remember but it certainly looks like slow motion. So what I noticed is a delay proportional to the speed decrease, and the difference in pitch one would expect. But the sound is not choppy anymore.
Ansa89
« Reply #541 on: February 13, 2012, 06:04:14 am »
On my system tekken3 runs at 99% - 100%, galaga at 100% and everything is ok, but sound (for tekken3) is delayed.
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« Reply #542 on: February 16, 2012, 12:33:10 am »
Anyone fancy to compile a 64-bit binary for the new groovymame?  I have a 64-bit hard-drive install and I tried to use the updated 32-bit binary but it was unsuccessful...lots of flickering on my d9200.  I've compiled windows binaries before but I'm about useless under linux.  I use the live-cd because it "just works" out of the box.   :cheers:
My rom set is from .143u9...will the .145 binary cause the cave games to dissapear??
Ansa89
« Reply #543 on: February 22, 2012, 06:51:22 am »
I upgraded groovymame patch, so it can be applied to mame 0.145u1.
Compiling notes
1) 0145u1.diff (http://mamedev.org/updates.html)
2) hi_145u1.txt (http://mamestuff.lowtrucks.net/MKChamp/)
3) 0145u1_groovymame_013e.diff
PS: I also found a bug (in mame core) about ldresample. If you need that binary, don't upgrade.
Calamity
  • Moderator
« Reply #544 on: February 22, 2012, 07:10:57 am »
That's great! Thanks :)
Ansa89
« Reply #545 on: February 22, 2012, 08:55:06 am »
Why can't you compile it yourself?
It gives you some errors?
Probably yes.
Calamity
  • Moderator
« Reply #546 on: February 22, 2012, 11:54:57 am »
Well, I understand dmarcum99 here, compiling Mame is not an easy task for everybody.
For instance, I'm compiling the Windows binaries now routinely, but don't have a clue of how to set my system up for Linux compiling. I'd like to, but have read I need Cygwin and stuff...
That is a fact.
senorchris
  • Last login:March 14, 2016, 11:57:10 pm
« Reply #547 on: February 23, 2012, 12:25:34 am »
Hi Calamity,
I was trying to compile the x64 version of GroovyMAME tonight, and I think I found a small bug that would only affect the Windows x64 version, and only at compile time.  In osd\windows\window.c, you're patching in the following snippet:
Code: [Select]
@@ -1431,6 +1543,8 @@
  // syscommands: catch win_start_maximized
  case WM_SYSCOMMAND:
+ mame_printf_verbose("window_proc: WM_SYSCOMMAND %d\n", wparam);
  // prevent screensaver or monitor power events
  if (wparam == SC_MONITORPOWER || wparam == SC_SCREENSAVE)
  return 1;
The problem is, in the x64 compiler, the wparam variable (a WPARAM type) is a 64-bit integer, and doesn't like being printf'd as a %d.  Casting it to a 32-bit integer lets it compile fine.  More info here.
This should fix it (it compiles at least, will let you know if I run into any bugs when I get a chance to use it):
Code: [Select]
  case WM_SYSCOMMAND:
+ mame_printf_verbose("window_proc: WM_SYSCOMMAND %d\n", (UINT32)wparam);
  return 1;
Cheers - I really appreciate all you're doing for the community!
Ansa89
« Reply #548 on: February 23, 2012, 02:22:56 am »
Someone else find it out: bug 4697, bug 4698.
These issues will be fixed in update2.
Calamity
  • Moderator
« Reply #549 on: February 23, 2012, 06:10:03 pm »
Thanks senorchris for pointing this and your explanation, that's true. I had to fix it when building the 64-bit binary but forgot to include it in the diff.
Ansa89
« Reply #550 on: February 24, 2012, 05:03:30 am »
I think it's time for official 0.145u1 groovymame patch to be uploded ;D .
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #551 on: March 02, 2012, 09:05:38 pm »
Any reason why I lose my control settings when updating to this version?
jimmy2x2x
« Reply #552 on: March 10, 2012, 04:01:04 pm »
does the binary 'groovymame64_0145.013e.rar' have working high score support?
Ansa89
« Reply #553 on: March 10, 2012, 04:05:21 pm »
Every groovymame binary should have high score support (it's a prerequisite in order to apply groovymame patch).
jimmy2x2x
« Reply #554 on: March 10, 2012, 04:06:54 pm »
Is it working for you?
Calamity
  • Moderator
« Reply #555 on: March 10, 2012, 04:11:15 pm »
Yes it has, but make sure to place the hiscore.dat inside the \hi folder, contrary to other builds where you just place it in MAME's main folder. This was done like this for compatibility with Linux.
Ansa89
« Reply #556 on: March 10, 2012, 04:14:34 pm »
I don't use the prebuilt binary, I compile groovymame by myself.
Moreover I use it under linux, so I can't test it.
My previous post was only a thought (since I know how the groovymame patch works), for a correct answer we must wait Calamity.
EDIT: @Calamity: posted at the same time...
« Last Edit: March 10, 2012, 04:17:02 pm by Ansa89 »
jimmy2x2x
« Reply #557 on: March 10, 2012, 04:38:24 pm »
that did it, cheers!
Paradroid
    • SCART Hunter
0.145u4 build?
« Reply #558 on: March 15, 2012, 04:56:58 pm »
Any chance of a 0.145u4 build? Usually I'm not that fussed about waiting for the next release but in this case I'm keen to try out the new CPS1 clones, especially the so-called "Street Fighter II Champion Final Japanese Version".
Calamity
  • Moderator
« Reply #559 on: March 17, 2012, 03:55:15 pm »
Version 0.145u4 is uploaded:
groovymame32_0145u4.013f.rar
groovymame64_0145u4.013f.rar
groovymame64_0145.013e_wiimote_linux.tar.bz2
0145u4_groovymame_013f.diff
Thanks go to:
- VeS for building the Linux binaries including Wiimote support.
Compiling notes
1) 0145u1.diff -> 0145u2.diff -> 0145u3.diff -> 0145u4.diff
3) 0145u4_groovymame_013f.diff (http://mario.groovy.org/GroovyMame/WindowsATIDrivers/)
Notes about the 013f groovymame patch
The syncrefresh option has been slightly modified since it was moved back to the core in patch 013e, now it works smoother when pausing/resuming, etc. Basically I have reconstructed the implementation that once existed in MAME v0.113, when the throttle function still checked for syncrefresh. Since MAME v0.114, the throttle mechanism and the syncrefresh option were separated, as the throttle function was moved into the core but the syncrefresh was kept -inexplicably- in the OSD part. For the first time, I'm considering submiting this as a patch for main line MAME.
For some reason, the OS independent 'soundsync' patch introduced in 013e can break the sound in Linux, this happens when pausing/resuming, but also can produce some lag issues it seems. Until we figure out the reason, it's possible to disable it by commenting these lines in src\emu\video.c:
Code: [Select]
void video_manager::recompute_speed(attotime emutime)
//if (m_syncrefresh && m_throttle)
// m_speed = m_speed_percent * 1000;
Patch 013f also fixes a problem with -changeres that still remained, and caused games to lock under some circumstances. Hopefully this is finally fixed.
« Last Edit: March 18, 2012, 04:17:51 pm by Calamity »
