Author Topic: What is the exact ref. or name of this part? Help needed  (Read 4682 times)
noobsaibotmk
  • Last login:February 21, 2013, 08:51:21 am
« on: April 02, 2011, 04:13:52 pm »
Hi,
I am restoring my MK3 cabinet and I need several parts like this (see attached pictures below).
The point is : there are several parts, 2 parts wich need to be stripped with the wires, and they are both linked by a "S" plastic part between them.
I thougt it was "Molex KK housing" but I was wrong and received unuseful parts from jammaboards.com (http://www.jammaboards.com/store/connectors-pins/3-96mm-156-molex-connectors/cat_4.html).
Can you help me please?
Thank you in advance !  :)
(MK, uMK3 & MK4 dedicated cabinets owner.)
Q*Bert_OP
  • Oh yes, we did!
Re: What is the exact ref. or name of this part? Help needed
« Reply #1 on: April 04, 2011, 02:24:22 pm »
The "Z" connector between the 2 female .156 molex plugs is WMS part number 5791-12235-XX, XX is the number of pins. The WMS part number is pretty useless though.  :-\
The female housings in the picture are IDC(insulation displacement style). The crimp-on pins give a more reliable connection. If you bought male headers as well, you can solder two of them together to make a "Z" connector.
noobsaibotmk
« Reply #2 on: April 04, 2011, 02:39:11 pm »
Than you very much for your help, I appreciate ! 'Will now try to find a website to order it  ;)
noobsaibotmk
« Reply #3 on: May 02, 2011, 11:19:29 am »
Hi again... I just cannot find these parts... Can you help me with a direct link please?  :(
Beley
  • Last login:September 14, 2013, 09:02:37 pm
« Reply #4 on: May 11, 2011, 09:52:25 pm »
The part with the wires in it is called a "discrete wire IDC".  Here is a digikey link:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A31273-ND
I am assuming that the wires are 22AWG, if not its available in other sizes.
As for the "S" part, could you post an image of it?
noobsaibotmk
« Reply #5 on: January 03, 2013, 10:53:08 am »
Hello ...
Sorry for my late reply ... I'm still looking for this component.
It is indeed a diameter of 22awg. I'm not sure this is the "discrete wire IDC."
Can you help me with these additional photos please?
Thank you in advance!
noobsaibotmk
« Reply #7 on: January 03, 2013, 05:13:50 pm »
http://www.marcospecialties.com/pinball-parts/045-5012-24
Fantastic.  ;) Can you please help me finding the correct female part of this connector, and the good crimp tool? I am looking for on this site but I am affraid to make a mistake!   :dunno
TopJimmyCooks
« Reply #8 on: January 03, 2013, 05:26:50 pm »
heres a kit with two 10 wire connectors and pins.  you need a .156 molex crimper tool too
http://www.digikey.com/product-detail/en/76650-0099/WM8438-ND/2116002
What you are looking for are .156" molex KK connectors.
noobsaibotmk
« Reply #9 on: January 03, 2013, 05:29:33 pm »
Thanks, I will check it!
Beley
« Reply #10 on: January 05, 2013, 11:18:35 pm »
The female ICD connector from your first post.
http://www.marcospecialties.com/pinball-parts/5792-10847-11
in your second set of images its the same thing just the 10 pin version (vs 11)
http://www.marcospecialties.com/pinball-parts/5792-10817-10
as for the tool needed:
http://www.marcospecialties.com/pinball-parts/77-IDC156
or
http://www.digikey.com/product-detail/en/360X30049X/626-1335-ND/1933544
note that if your careful you can push the wires down using a small screwdriver
if you go with the KK style that TopJimmy linked to you need something like this:
http://www.marcospecialties.com/pinball-parts/77-CTW
again with some patience you can do it with a samll pair of needle nose pliers, but the crimper is much easier in this case.
noobsaibotmk
« Reply #11 on: January 06, 2013, 02:17:16 pm »
Thank you very much for your help!!  :applaud:
TopJimmyCooks
« Reply #12 on: January 06, 2013, 02:33:21 pm »
I would never recommend using an insulation displacement connector.  use the crimped pin connectors.  they are more reliable and more widely used these days.
noobsaibotmk
« Reply #13 on: January 06, 2013, 04:47:45 pm »
Do you mean KK connectors when you say "crimped pin connectors" or am I wrong?
TopJimmyCooks
« Reply #14 on: January 06, 2013, 07:19:21 pm »
yes.
