Author Topic: Hantarex mtc 9110 vertical sync problem  (Read 2812 times)
ginocomino
  • Last login:September 09, 2011, 01:20:04 pm
« on: March 23, 2011, 07:45:30 pm »
Configuration : Hantarex mtc 9110 monitor (old cabinet)
j-pac
vga arcade 3000
the original game  ran perfectly, but as soon as I connected j-pac,arcade vga 3000 and my pc it was impossible to keep the image stabilized vertically. I changed the v-sync 10k potentiometer with a new and better one but same result... as soon as the image looks stilll after few seconds it starts to roll upwards....
any hint?
I have googled around and found many people with the same problem but couldnt find a solution
TIA
grantspain
Re: Hantarex mtc 9110 vertical sync problem
« Reply #1 on: March 24, 2011, 11:34:03 am »
there was an old trick with hantarex monitors whereby you attach a 5k resistor from vertical sync to ground on the video input plus
ginocomino
« Reply #2 on: March 25, 2011, 05:13:19 am »
I read about it
http://forum.arcadecontrols.com/index.php?topic=86606.0
but it sounds like a "work in progress", not a final solution...
