Author Topic: Four Million B.C. restoration project road block!  (Read 2651 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: March 23, 2011, 09:44:41 am »
You guys have any ideas on where to find a replacement 'close flipper' coil for a Bally Zipper Flipper assembly? This is not a standard coil - it's mounted in a metal frame with square core. My unit is shorted, but since I can't remove the actual windings from the frame, I can't rewind it myself. The part number is E-184-239. I've tried a dozen different sites that carry pinball parts, but no luck. Without it, my Four Million B.C. restoration project is on hold. Any suggestions?
Robots will kill you.
Arcade Addiction
arzoo
    • LEDBlinky
Re: Four Million B.C. restoration project road block!
« Reply #1 on: March 23, 2011, 10:29:17 am »
Give that dickbag at Pinball Resource a call.  Also try For Amusement Only.  You're going to have to actually call them, though.
Don't think highly of pinball resource?  ;)
Arcade Addiction
