Author Topic: Splash screen after hibernation  (Read 3728 times)
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« on: March 20, 2011, 10:39:52 am »
Hi loadman, thanks for your great work...Mala is fantastic!
I test your 1.741 beta version, work fine, thanks for add hibernate function!
I have problem with image splash screen that appear after hibernation, this image is very big for my screen, i use low resolution (512x240), is possible cut the image?
Thanks!  :applaud:
loadman
  • Moderator
    • MaLa
Re: Splash screen after hibernation
« Reply #1 on: March 20, 2011, 11:14:51 pm »
Hi.
That is on my list of things to do I think  ;)
This is the same request as this one isn't it?
http://forum.arcadecontrols.com/index.php?topic=110337.msg1169261#msg1169261
Or is there a subtle difference I am missing?  ???
PaTrYcK
« Reply #2 on: March 21, 2011, 10:58:13 am »
Hi.
Great loadman  :applaud:
Yes, but in that post I asked if it possible choose your own image, now I have indicated that the image is very, very big ::)
« Last Edit: March 21, 2011, 11:04:59 am by PaTrYcK »
PaTrYcK
« Reply #3 on: June 04, 2011, 11:07:53 am »
Hi loadman !
When you think is possible add new feature for this problem?
Thanks!  :applaud:
loadman
  • Moderator
    • MaLa
« Reply #4 on: June 04, 2011, 09:49:35 pm »
O yeah,
I will do this now.
No more splash screen after Hibernate
[Later]
Done.
Will be in next beta
« Last Edit: June 04, 2011, 10:43:14 pm by loadman »
PaTrYcK
« Reply #5 on: June 05, 2011, 11:45:25 am »
O yeah,
I will do this now.
[Later]
Done.
loadman you are the best!
 :applaud: :applaud: :applaud:
PaTrYcK
« Reply #6 on: June 19, 2011, 09:38:58 am »
Hi loadman, i test last beta 1745, now after hibernate the screen show: "Mala starting..."
I usually use mala version 1739c , in this version not is available splash screen and after hibernate the screen show "Mala restarting after stanbye or Hibernation..."
I set mala so that appear immediately snap  of the game and video preview after 3 second, if anybody move joystick or press button: start the screen saver after 2 minuts...
There is one difference between two versions, in version 1739c after hibernation start immediately snap of the game, then start video preview and after 2 minuts start the screen saver, instead in the last version after hibernation the screen show only the snap, no preview or screen saver.... for start fine mala i must move joystick or press button one time, after is all ok...what is changed?
« Last Edit: June 19, 2011, 09:52:32 am by PaTrYcK »
loadman
  • Moderator
    • MaLa
« Reply #7 on: June 19, 2011, 09:29:51 pm »
So are you saying that after resuming from Hibernation or Standby that the preview videos or screensaver don't start unless you move the game list?
PaTrYcK
« Reply #8 on: June 20, 2011, 07:37:06 am »
Exactly!
