Author Topic: DK Path element  (Read 1153 times)
Terry
  • Last login:June 16, 2019, 07:43:56 pm
DK Path element
« on: August 24, 2003, 05:00:17 pm »
I am using DK8.1 and I recently included the path element in my skin.  The default setting in frontend.ini is set up to cycle through 3 different elements, the caption, gamename, and category.  (PathCycles=-1|1|6)
I do not want to cycle through these elements, but just to display the game name.  I have tried setting PathCycles=1, assumig the numbers relate to the dir.ini searchstring and filters numbers.
When I have it set this way, it only displays the caption I have entered in my dir.ini file.  I played around with it a bit, but I can not get just my game name to display unless it is in the cycling format I listed above and actively cycling.
Thanks for any help,
Terry
Terry
Re:DK Path element
« Reply #1 on: August 24, 2003, 05:04:22 pm »
Well I just figured out a way to do it, but I don't know it is the proper way.
I set PathCycles=1|1|1 and it seems to work ok.
Any comments on this method?
Terry
  • Last login:Today at 02:06:09 am
Re:DK Path element
« Reply #2 on: August 24, 2003, 11:35:35 pm »
To use path cycles you have to have at least two elements listed, thus the name.  ;)
Terry
Re:DK Path element
« Reply #3 on: August 25, 2003, 01:23:44 am »
How would you disable path cycles to just display the game name in the path element?
Re:DK Path element
« Reply #4 on: August 25, 2003, 02:43:45 pm »
How you did it.  As I said, it's path cycles.  It isn't designed to show 1 of anything.
Terry
Re:DK Path element
« Reply #5 on: August 25, 2003, 03:08:34 pm »
Thanks! :)
