Author Topic: ultrasticks 360 analog issue  (Read 1528 times)
danivempire
  • Last login:November 05, 2014, 01:50:57 pm
« on: March 06, 2011, 08:53:02 am »
Hello
I got a problem with one of my 2 ultrasticks 360
I noticed that in analog mode, on of them have a smaller ranger than the other one, they have the latest firmware both of them and I reprogrammed them both at the same time.
I also noticed that the joystick who has this problem, that the led on the pcb is not working, is that connected to the analog problem???
ps: The sticks works fine in not-analog mode
Bender
Re: ultrasticks 360 analog issue
« Reply #1 on: March 06, 2011, 01:35:05 pm »
danivempire
« Reply #2 on: March 06, 2011, 02:18:15 pm »
thank you, it helped me solve my problem
For my case, I just put "circular restrictor" and it works I can go to all corners even that I don't have any restrictor installed (so far).
 :notworthy:
As the sticks works fine, all directions are detected and play fine, do you think I should worry about this pcb led that doesn't work???
danivempire
« Reply #3 on: March 07, 2011, 11:59:32 am »
I've sent the issue to andy at ultimarc (and jan from arcadeshop, where I bought my sticks)
They will send me a new pcb  :notworthy:
