Author Topic: Radeon x1300 video card won't detect my TV on component cable  (Read 1324 times)
ebo0763
  • Last login:May 23, 2016, 12:37:58 am
My radeon x1300 (on XP) doesn't detect the tv which is connected with a 7 pin DIN as component (YPbPr). The screen is just black and when there is a change in display on my main monitor, my tv will flicker once. So it's alive I guess.
My TV can only accept 480i from component, it's a later crt model.
I used a standard DIN to YPbPr adapter but also another one with apparently the right layout but they won't work.
This is supposed to be for Radeon :
7 pin mini-DIN female connector layout at the videocard
Pin Name Description
1 GND Ground (Y)
2 GND Ground (C)
3 Y Component: to green RCA
4 Pr/Cr Component: to red RCA
5 GND Ground
6 GND Ground
7 Pb/Cb Component: to blue RCA
So what could be wrong here?
