Author Topic: Amiga 1084s monitor for mame  (Read 5270 times)
s7eroid
  • Newbie
  • Last login:August 23, 2003, 04:08:11 pm
« on: August 23, 2003, 04:15:23 pm »
Can anyone tell me if the Amiga 1084s monitor is any use for mame? I want to build a bartop and use the 13" 1084s. Is there anyone out there that has with succes used the 1084s for mame? let me know please :) thanks
RandyT
    • GroovyGameGear.com
Re:Amiga 1084s monitor for mame
« Reply #1 on: August 25, 2003, 02:29:43 pm »
The 1084s has stereo speakers (thus the "s") and is RGB capable at 15.75khz, so it should work with the ArcadeVGA card without too much trouble.
I think it may also have composite and LUMA/CHROMA (separated S-vid) inputs, but will require an adapter if it does and you want to use S-Video.
RandyT
Tailgunner
« Reply #2 on: August 26, 2003, 08:21:23 pm »
bluemanop
  • Last login:April 16, 2005, 03:47:21 pm
  • Life is but a game, why not play some?
Re: Amiga 1084s monitor for mame
« Reply #3 on: March 14, 2005, 09:32:37 am »
Anyone have a newer link? This one is old and busted.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: March 14, 2005, 09:52:45 am »
I've got one I use as a test monitor.
There are several version of each of the 1084's.
The one I have takes positive vertical sync and negative horziontal sync.
I just built a cable with a 7404 inverter in it to handle the sync correction.
Looks great with a avga card.
Later,
dabone
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #5 on: March 14, 2005, 12:50:18 pm »
Yvan256
    • Yvan256
« Reply #6 on: May 15, 2009, 05:29:32 pm »
this guy used one
http://yvan256.net/projects/mamecade/
It's connected via S-Video, not VGA or anything fancy.
Level42
« Reply #7 on: May 17, 2009, 05:23:41 pm »
Which is stupid because you can use RGB on these monitors as long as it's 15 kHz of course. I've got two of them (one I use for testing, the other may go in a cocktail table.....) Both are the Philips built' version, they don't make stuff like that anymore I tell you. These little monitors rock :)
Jack Burton
« Reply #8 on: May 18, 2009, 08:07:42 am »
Agreed.
Small CRTs last practically forever.  My best monitors to this day are little Sony professional video monitors.
And who can forget Zenith black and white 13" tv's?  Toughest.TV.ever.
Yvan256
    • Yvan256
« Reply #9 on: May 27, 2009, 02:07:45 pm »
Since this cabinet uses a plain old PCI ATI video card, I don't see how else I would connect it apart from S-Video. Mind you, I haven't really searched about the possibilities with the 1084...
Jack Burton
« Reply #10 on: May 28, 2009, 09:05:02 am »
What model of video card is it?  You might be able to use soft 15khz.
Yvan256
    • Yvan256
« Reply #11 on: May 30, 2009, 03:08:16 pm »
ATI Rage Pro Turbo PCI. Though I don't know how to connect the 1084 to the VGA port...
SailorSat
  • Last login:February 07, 2026, 07:38:58 pm
    • For Amusement Only e.V.
« Reply #12 on: June 06, 2009, 10:57:09 am »
There are several versions of the 108x
Some have a 9 Pin D-Sub Input, others have a 6 Pin DIN Input, again others have an 8 Pin DIN Input and even others have a SCART Plug.
On the PC side you'll most likely want to use VGA output.
In any case you'll have to build a cable. Either solder one yourself, or "cut" an old VGA extension cable.
As for your graphics card...
Well with a Rage Pro you CAN use it with VGA if you are running DOS (AdvanceMAME) or Linux, with Windows however you're pretty much boned VGA wise.
You could try to get a Radeon 9200 PCI somewhere instead. Pretty cheap nowadays.
« Last Edit: June 06, 2009, 10:58:59 am by SailorSat »
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Ummon
  • Trade Count: (+13)
« Reply #13 on: June 06, 2009, 07:22:45 pm »
Hah hah hah hah. Such strong language.
Pretty much. In any case, all implications to read the.....now what does part of my sig say?
Yo. Chocolate.
Stephen Hawking
