Author Topic: 25" K7000 Help  (Read 3068 times)
Devryn
  • Last login:May 28, 2011, 10:53:15 am
25" K7000 Help
« on: February 26, 2011, 04:52:30 pm »
What it's doing now:
Series of events:
1.  Blew fuses.
2.  Sent to member on KLOV for refurbishment.  He replaced flyback, D20, D21, and R103.
3.  I got it back, plugged it in on my bench and it worked great.
4.  I put it in the cabinet, but forgot to reconnect anode cap.  It arced from somewhere.
5.  It was blowing fuses again.
6.  Replaced D20, D21 (with 1N4005), VR, and HOT
7.  It gave a scrambled picture.
8.  Replaced IC3
9.  Now its doing what I linked to.
Help.  :(
« Last Edit: February 26, 2011, 05:05:08 pm by Devryn »
Naukuga
  • Last login:March 02, 2011, 02:37:58 am
Re: 25" K7000 Help
« Reply #1 on: February 26, 2011, 05:14:51 pm »
Check your monitor ground! i had a screen that was doing something similar, and i ended up finding the ground wire wasnt hooked up right. My board arced to the frame and fried.
Devryn
Re: 25" K7000 Help
« Reply #2 on: February 26, 2011, 05:29:18 pm »
Ground wire from the tube to the neckboard seems fine.
Kevin Mullins
    • Me on Myspace
Re: 25" K7000 Help
« Reply #3 on: February 26, 2011, 05:36:49 pm »
Have you tried adjusting the Horizontal Hold and 50/60Hz pots ?
Is the SYNC wired connected properly on the video cable ?
Devryn
Re: 25" K7000 Help
« Reply #4 on: February 26, 2011, 06:10:34 pm »
None of the pots make much difference.  The rgb and sync are hooked up:
Rgb--- g-s
Devryn
Re: 25" K7000 Help
« Reply #5 on: February 26, 2011, 06:59:28 pm »
Is there any chance that the Diodes I replaced are causing this?  The 1N4005's are 1 Amp 600 Volt.  I believe that the 1N5061's that were in there were 3 Amp 600 Volt...
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: 25" K7000 Help
« Reply #6 on: February 26, 2011, 08:12:19 pm »
the diodes should be replaced with proper ratings .
HOT chassis  ! must use isolation xformer .
d21,22 would be a frequent failure without isolation
C57 is a common failure
also check c23
and check sync/H hold per Kevin  ;D
Devryn
Re: 25" K7000 Help
« Reply #7 on: February 26, 2011, 08:24:43 pm »
Diode ratings are in accordance with service manual.  Already checked sync.
Kevin Mullins
    • Me on Myspace
Re: 25" K7000 Help
« Reply #8 on: February 26, 2011, 10:38:08 pm »
Do you have another game you can hook up to that monitor?
Or vice versa, take that game and connect to a different monitor?
Just to verify if it is a monitor problem or if it is a game pcb problem.
Wanna make sure you didn't zap the game pcb and knock something out in the video ouput section.
Devryn
Re: 25" K7000 Help
« Reply #9 on: February 26, 2011, 10:57:04 pm »
I don't.  :(
