Author Topic: NEED HELP QUICK  (Read 1990 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
NEED HELP QUICK
« on: August 21, 2003, 07:39:07 pm »
How do you hook up a WG D9200 to a comp. power supply?
Derek
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:NEED HELP QUICK
« Reply #1 on: August 21, 2003, 07:50:38 pm »
you don't....
it (the monitor) uses AC
computer powersupplies output DC....
if you are asking how to turn on your monitor when you computer turns on, well that's covered in the main forum recently...
What did you really want to know? (and i'll do my best to answer)
Rampy
Are you asking if it uses the same cord? or ???
« Last Edit: August 21, 2003, 07:54:10 pm by rampy »
crashdmj
  • Hulk smash!
Re:NEED HELP QUICK
« Reply #2 on: August 21, 2003, 08:04:44 pm »
Ok I am basically asking how do I turn my D9200 on lol. I dont know how I missed this part of the project, I overlooked it. What cord can I get to get it some juice.
Derek
Gromet
  • Last login:October 31, 2003, 10:11:45 am
Re:NEED HELP QUICK
« Reply #3 on: August 21, 2003, 08:52:57 pm »
The D9200 comes with a power cord, one end has a 4 wire white plastic connector that plugs onto the monitors controller board, the other end plugs into a standard house three prong grounded outlet.  There is no power switch on the D9200 so when it is plugged into a "HOT" power source it just turns on.  Some people plug it into a power strip and use that for their power button, some into a switched outlet.
Recently the BITS SMARTSTRIP was reviewed by Kevin of RetroBlast, I'm sure if you do a quick search you can find his thread.  Basically the BITS is a pretty cool power strip.  Plug your PC's power coard into the controller port of the smart strip and than everything else, Marquee light, monitor, speakerc etc... into the other outlets.  When your pc's power button is pressed or turned on, it automatically juices up the pother compinents plugged into the strip.  when you power down your PC the strip detects it, and turns everything else off.  The strip sells for around $30.00 and reviews have been pretty good so far.
Hope that helps...
crashdmj
  • Hulk smash!
Re:NEED HELP QUICK
« Reply #4 on: August 21, 2003, 09:01:58 pm »
Damn it, they screwed me. My monitor didn't come with a power cord, first the pack it (lousy -- edited by saint) and now they screw me, it better work. Thanks for the help
Derek
« Last Edit: August 21, 2003, 09:15:38 pm by saint »
matt888
  • Last login:September 02, 2003, 12:18:03 am
Re:NEED HELP QUICK
« Reply #5 on: August 21, 2003, 09:34:06 pm »
I don't mean to laugh, but give the monitor a few days and "missing the power cord" will be the least of your worries because the screen may go green/grey permanently!  What a deal for over 400 bucks eh?  :o
Gromet
Re:NEED HELP QUICK
« Reply #6 on: August 21, 2003, 10:01:50 pm »
i've had mine for almost two months and haven't had any problems... clear, and vivid colors, LOVE it....
