Author Topic: XP64 + Hyperspin + LEDBlinky + u360s (No LEDs)  (Read 2455 times)
DillonFoulds
« on: February 11, 2011, 12:06:35 am »
...Title pretty much sums it all up...
Running Windows XP (64-bit)
Got all of hyperspin wheels configured, all emulators open and run games near perfect, with a handful of exceptions....
Now I'm looking at configuring Hyperspin to play nice with LEDBlinky to program my u360's on the fly. I've got a 4 player panel, with only 2 u360s (2 mag sticks for p3/4 for the time being, but i doubt they'll stay...)
In LEDBlinkyConfig.exe...
-Set my mame \cfg\ folder
-Set controls.ini (grabbed from controls dat here @ byoac)
-Set mame.xml (generated from mame using "mame.exe -listxml >mame.xml").
-Set the FE to hyperspin, and configured the pathing for hyperspin\settings\settings.ini.
-Checked "No LEDs Mode" (I don't have any)
-Set JDR Mode for u360, and set control panel max players to 2 (again, 2x u360s, 2x mag-sticks)
I've configured hyperspin to use LEDBlinky with the correct path.
Now when i boot windows, hyperspin loads, i get the ledblinky splash screen (only on free LEDBlinky, for now). Then I get an Access Violation with regards to PacDrive.dll
Also it appears that the joysticks don't work in hyperspin. I've got them programmed to 8-ways?
Is there something I'm missing? Would someone mind giving me a fool-proof guide to configuring LEDBlinky? I've changed the very few options that ity appears I need to, what Could I be missing?
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: XP64 + Hyperspin + LEDBlinky + u360s (No LEDs)
« Reply #1 on: February 11, 2011, 10:16:15 am »
There's a bug with LEDBlinky v5 when using the No LEDs Mode that causes the pacdrive.dll crash. I'll post the fix tonight. Sorry about that.
Robots will kill you.
Arcade Addiction
arzoo
    • LEDBlinky
« Reply #2 on: February 11, 2011, 08:15:43 pm »
Here's the updated exe - v5.0.0.1
« Last Edit: February 11, 2011, 08:17:16 pm by arzoo »
Arcade Addiction
DillonFoulds
« Reply #3 on: February 11, 2011, 08:22:42 pm »
Thanks so much arzoo! It's 404'ing now, but i'll check back periodically through the night.
With service like this you're gonna sucker me into purchasing it reeeeaaaallll quick...
arzoo
    • LEDBlinky
« Reply #4 on: February 11, 2011, 08:59:24 pm »
Just tried and the download worked fine. I had renamed the file - so maybe try a refresh first.
Hmmm, the site is very slow - something must be up with my isp.
« Last Edit: February 11, 2011, 09:06:48 pm by arzoo »
Arcade Addiction
DillonFoulds
« Reply #5 on: February 12, 2011, 05:11:36 pm »
Thanks Arzoo, that did the trick!
